Best MagSafe chargers 2024
The best MagSafe chargers are the ultimate in convenience
MagSafe was introduced with the iPhone 12 and MagSafe accessories like chargers have grown in popularity in the years since. MagSafe chargers are an improvement over regular wireless chargers for several reasons. First of all, they can charge your iPhone or above with 15W of power if used with a 20W or higher wall charger. Secondly, the ring of magnets clicks your iPhone into place, so you know it won't slip off the charger.
The added speed and peace of mind make MagSafe chargers quite appealing, and there are tons to choose from. We've narrowed down some options for you, depending on your situation and your taste. Here are the best MagSafe chargers for you.
Best overall
Best overall
The official Apple MagSafe charger is a simple magnetic disk that attaches magnetically to your iPhone to provide 15W of charging power when used together with a 20W charging brick, making it one of the best MagSafe chargers. Predictably, no charging brick is included, so you'll need to buy it separately. The Apple MagSafe charger also has Qi compatibility so you can charge any wireless compatible device with it. However, such devices won't attach magnetically or charge at its maximum speed. That's limited to MagSafe compatible iPhones.
Convenient
3 chargers in 1
Belkin's MagSafe 3-in-1 Wireless Charging Stand doesn't just charge your MagSafe compatible phone. It also works as a charger for your AirPods and Apple Watch, so it's a good all-rounder. Looking pretty stylish, it'll fit on your bedside cabinet or desk well, while consistently charging quickly and efficiently at up to 15W.
Power up
True wireless charging
If you want the option to charge your iPhone and Apple Watch completely wire-free, check out the OtterBox 2-in-1 Power Bank with MagSafe. Charge it up and take it with you; the 10,000 mAh battery gives you plenty of juice. In our review, we noted that it can be used in different positions, either as a charging pad or a stand. This allows you to use either StandBy mode or Nightstand Mode but not both at the same time. While it's fairly bulky for travel, the fact that it's a battery too makes it worth consideration.
Coolio
Cool charger
If you're concerned about overheating, TORRAS 3-in-1 Charging Station is a cool pick. As noted in our review, a fan inside cools your iPhone while it charges vertically or horizontally (so you can use StandBy mode.) It also charges your AirPods and Apple Watch at the same time. The Apple Watch charger can be removed and used separately if you prefer. The entire charger folds up for portability.
Fold it up
Super charge on the go
Looking for something that folds up small enough to pop into any tech bag or purse? Check out the KU XIU 3-in-1 Foldable Magnetic Charger. Our reviewer really liked the extremely compact form factor, reasonable price, and ability to charge iPhone, Apple Watch, and AirPods at once. It comes with the cable and wall charger you'll need, plus a sturdy carrying case. Note that you can use StandBy mode on your iPhone but not Nightstand Mode on your Apple Watch.
AirPods too
Anker 2-in-1
Ideal for AirPods owners who want to charge their earbuds at the same time as their phone, the Anker PowerWave charges with up to 7.5 watts of power. It's also possible to attach your phone either vertically or horizontally if you want to watch a movie while it charges. You can use StandBy mode, which makes this a great desk or nightstand companion.
Fold for travel
Fold up magnetic charger
Able to fold up and be far more portable than you'd think, the Petino 3 in 1 Charging Station for Apple will charge your iPhone, AirPods, and Apple Watch all while looking pretty stylish at the same time. Both the MagSafe iPhone charging puck and Apple Watch charging puck can be used in two different positions, flat or standing up. Because the iPhone and Apple Watch charging areas are so far apart, you can easily use StandBy mode and Nightstand Mode at the same time.
Drive and charge
Magnetic car charger
Able to grip onto your phone even during bumpy rides, the ESR MagSafe Car Charger offers secure mounting alongside MagSafe charging. You can twist your phone too to use it in either landscape or portrait mode, all while being safely out of your hands. Finally, you can use Apple Maps and not have to worry that your iPhone will be out of power when you arrive at your destination. Pair it with one of the best wireless CarPlay adapters to give your slighter older vehicle a serious upgrade.
Slick
Snap and go
This is similar to Apple's MagSafe Battery Pack, only it's a bit bigger and gives you a whole lot more juice. Battery packs are a travel essential. Since this one just snaps onto the back of your iPhone and stays in place, you can use your iPhone while you charge it. A handy kickstand on the back lets you watch videos on the go or use StandBy mode. The UGREEN 10,000mAh 20W Magnetic Power Bank also has two USB-C charging ports, meaning you can charge up to three devices at once.
Can I use a MagSafe charger for other devices?
Sometimes. If it's a flat charger, like the Apple MagSafe charger, it can also be used as a wireless charger for any Qi-compatible device including older iPhones. However, if it's an upright stand-style MagSafe charger, then simple gravity will prevent it from charging older iPhones or any other devices lacking the MagSafe magnets holding it in place.
Which MagSafe charger should you buy?
The reason we included so many different kinds of options here is because there's no one-size-fits-all solution. If you're just looking for a simple MagSafe charger, Apple's own is a slim, quick, no-frills option. Many of us at iMore that do own an iPhone, Apple Watch, and AirPods prefer to use one of the 3-in-1 chargers. Charging all the devices together in one spot is a major convenience.
The UGREEN Magnetic Battery 10,000mAh Battery Pack with Foldable Kickstand is a travel essential, in case your iPhone runs low on power. You wouldn't want to have your translator/map/wallet/camera run out of power on the go, wouldn't you? Charge up your friends' phones too with the USB-C ports. Plus the kickstand makes it both an airplane and a nightstand companion.
**Mark Goldschmitt** is the father of three boys and loves anything Apple. Born and raised in Queens, NY, and currently residing on Long Island, Mark is a lifelong New York Mets fan. {.end}
