FosPower is offering savings on its rugged power bank, braided Lightning cables and more at Amazon
If you are in the market for some new accessories for your iPhone or iPad, you'll want to check out these savings from FosPower at Amazon. You can save on braided Lightning cables, a rugged power bank and more. With Lightning cables, you can never really have enough. A spare for your bag, desk or car is always a good purchase, and a rugged power bank to keep you charged while braving the elements is pretty awesome.
In order to get the savings with the coupon codes, you will need to pick FosPower as the seller. If you select FosPower with fulfillment through Amazon, the coupons may not work.
- FosPower PowerActive 10200mAh Rugged Power Bank - $24.99 (no code required)
- FosPower 4-Port USB Car Charger - $11.99 (no code required)
- FosPower Apple MFi certified Braided Lightning Cable – 3ft (Space Gray) - $6.99 with code FOSPWR06
- FosPower Apple MFi certified Braided Lightning Cable – 3ft (Gold) - $6.99 with code FOSPWR06
- FosPower 2-Pack Apple Mfi Braided Lightning Cable – 6-inch (Space Gray) - $8.99 with code FOSPWR05
- FosPower 2-Pack Apple Mfi Braided Lightning Cable – 6-inch (Gold) - $8.99 with code FOSPWR05
- FosPower 2-Pack Apple Mfi Braided Lightning Cable – 6-feet (Space Gray) - $8.99 with code FOSPWR07
- FosPower 2-Pack Apple Mfi Braided Lightning Cable – 6-feet (Gold) - $8.99 with code FOSPWR07
Will you be adding any of these accessories to your collection? If so, be sure to let us know in the comments which ones you went with!
