How to check the weather and get forecasts using Siri
Siri not only makes for a great digital assistant but a great weather forecaster as well. With a little help from Siri, you can make sure you're never caught without your umbrella, raincoat, snow shovel, or suntan lotion again.
How to check current weather conditions with Siri
How do you find out about the weather? Just ask Siri.
  1. Press and hold down the Home button to activate Siri.
  1. Ask Siri to check the weather. For example, "What's the weather today?"
Tap the weather widget to go to the Weather App.
How to view a weekly weather or future forecast with Siri
If you care more about the entire weekly forecast, or a specific day of the upcoming week, you can ask Siri to show you that instead, and highlight it for you as well.
  1. Ask Siri to tell you what the weekly weather looks like. For example, "What is the forecast for this week?" or "What's the weather on Friday?"
How to check the weather in a different location with Siri
If you're traveling or simply care more about the weather someplace else than you do at home, Siri can give you the same information for another area.
  1. Ask Siri to tell you the weather in another location. For example, "What's the weather like in Chicago?" or "Will it be hot in San Francisco today?"
You can also ask Siri more practical questions, like "do I need a rain jacket today". They'll call up the same weather widget, but they let you ask what you're specifically interested in finding out.
  1. Ask Siri if you need anything special to prepare for the weather. For example, "Do I need a coat today?" or "Will I I need an umbrella tomorrow?"
How to check sunrise and sunset times with Siri
Want to make sure you're up at the crack of dawn, or that you make it home before dusk? Siri can tell you that as well.
  1. Ask Siri to tell you when the sun is setting or rising. For example, "What time will the sun set tonight?" or "What time did the sun rise this morning?"
How to get more help with Siri
If you still need help with setting up or using Siri with your iPhone Calendar, or any other Siri feature, head on over to our Siri Forum and ask away!
Rene Ritchie
Contributor
