Apple Macos Sierra
Latest about Apple Macos Sierra
![How to set up FaceTime on your Mac](https://cdn.mos.cms.futurecdn.net/ie7UkeiGDSJ34cRz6juBH4-320-80.jpg)
By Joseph Keller published
Learn the ins and outs of your Mac's built-in app for calls, FaceTime.
![Macos Big Sur Siri](https://cdn.mos.cms.futurecdn.net/F72FL9h4ZHgcU7iJjHr2Rj-320-80.jpg)
How to use Siri on the Mac
By Bryan M Wolfe, Lory Gil published
Siri on the Mac can sift through your files and find your documents, help adjust your settings, search your pictures, tweet for you, and a whole lot more.
![Notes app on Mac](https://cdn.mos.cms.futurecdn.net/zEdC75ga3XVXN2sYsHJFCe-320-80.jpeg)
How to use tables in Notes on Mac
By Susie Ochs last updated
The Notes app lets you add tables to organize information and make it easier to read.
![Mac App Store](https://cdn.mos.cms.futurecdn.net/jM5HLdaFwhkQMaZH3c8kJb-320-80.jpeg)
How to turn on automatic app updates for macOS
By Rene Ritchie last updated
How do you make sure macOS app updates are always ready and waiting for you? With background updates!
![Safari on Mac](https://cdn.mos.cms.futurecdn.net/8LbPJUYKcHGrwdLto7zoTo-320-80.jpg)
How to customize website options for Safari on Mac
By Lory Gil last updated
You can customize your browsing experience with Safari for each website you visit. Reader View for some, autoplay for others!
![High Sierra Mac notifications](https://cdn.mos.cms.futurecdn.net/8jQmwKFe5sXmQ97AGzM5Ge-320-80.jpg)
How to set up and use Notification Center on your Mac
By Joseph Keller last updated
Master your Mac's Notification Center and take control of your Today widgets with this handy guide.
![null](https://cdn.mos.cms.futurecdn.net/o6ViuR9zJzkAjYXg5gt35W-320-80.jpeg)
How to enable automatic Reader View for specific websites in Safari for Mac
You can set up specific websites with Reader View in Safari for macOS.
![null](https://cdn.mos.cms.futurecdn.net/vrbKXd4LdNSTAnYSZ44JfL-320-80.jpg)
How to check to see if your Mac applications are 32-bit or 64-bit
By Mikah Sargent last updated
Starting in macOS High Sierra 10.13.4, launching 32-bit apps will display a warning. Here's how to check in advance to see which of your apps is at the end of its macOS shelf life.
![Use Touch ID to unlock 1Password on MacBook Pro Touch Bar](https://cdn.mos.cms.futurecdn.net/inj48dGJWpdZEJdoawGRZY-320-80.jpg)
Speaker or kernel panic issues with your MacBook Pro? Try this update!
By Rene Ritchie published
If you've experienced speaker noise and kernel panic issues with your MacBook Pro, macOS High Sierra 10.13.6 Supplemental Update 2 is here to help.
![null](https://cdn.mos.cms.futurecdn.net/N52ixtfbvf3n8V2NQxjNqC-320-80.jpg)
How iMessage effects work on older iPhones, iPads, and Macs
By Serenity Caldwell, Joseph Keller last updated
You can slam messages or send handwritten messages to fellow iOS 10 or macOS Sierra pals, but what will that look like for friends with older machines?
![How to use Finder on your Mac](https://cdn.mos.cms.futurecdn.net/qsmVjLzPYRDy5KttYqU9ZG-320-80.jpg)
How to download and install macOS 10.13.6 beta 5 to your Mac
By Lory Gil, Joseph Keller published
If you are a developer and want to know what to expect in macOS High Sierra, here is how to install macOS 10.13.6 beta 5.
![macOS High Sierra](https://cdn.mos.cms.futurecdn.net/hJRyUTDqjyNyfMYLMVBjXB-320-80.jpg)
How to download macOS High Sierra 10.13.6 public beta 2 to your Mac
The second public beta version of macOS High Sierra 10.13.6 is now available. If you want to try it out, here's what you need to know to get started.
![Resetting Mac](https://cdn.mos.cms.futurecdn.net/dCsNeiEKHku47o3PmNcZq3-320-80.jpg)
macOS High Sierra review: A radical new foundation for your Mac
![Photos app on iPad with MacBook in the background](https://cdn.mos.cms.futurecdn.net/kPZMdYfJyptGnPbbi7ABrn-320-80.jpeg)
How to save your iPhone photos directly to an external hard drive on Mac
By Luke Filipowicz last updated
![null](https://cdn.mos.cms.futurecdn.net/hfQwrV4QDEth8zWQxG8KJP-320-80.jpg)
How to get picture-in-picture for Netflix and Hulu on your Mac
Netflix and Hulu don't support Sierra's PiP feature, but you can still watch movies with a tiny pop-out window!
![null](https://cdn.mos.cms.futurecdn.net/HZ2LqhZKyynerfswXu7Gfk-320-80.jpg)
macOS High Sierra 'root' security bug: Here's how to fix it now!
![null](https://cdn.mos.cms.futurecdn.net/wiov7hJhkkd2dhpyVi2u4A-320-80.jpg)
Can't run Boot Camp in High Sierra? Here's the fix!
If you're having problems setting up Boot Camp on your Mac running macOS High Sierra, here's what you can do to try and fix it.
![null](https://cdn.mos.cms.futurecdn.net/GLZLq4rztacMABgKuhAFpU-320-80.jpg)
Apple Geniuses having trouble diagnosing problems with your Mac? APFS might be the reason
If Apple’s Geniuses have trouble diagnosing problems that your Mac is experiencing, APFS could be the reason.
