Will the LG 27UD88 monitor work with my MacBook Pro?
Best answer: Yes it will, but it may not efficiently charge your 15-inch MacBook Pro while you're using it. You'll have to close your MacBook or make sure it's off in order to get a full charge. The monitor will charge your 13-inch MacBook Pro without any issues.Amazon: LG 27UD88 monitor ($580)Amazon: LG UltraFine 5K ($1,490)Apple: MacBook Pro ($1,300 - $2,800)
While the LG monitor and your laptop are compatible, they may not be the most practical companions
You can definitely use the LG 27UD88 monitor with your MacBook Pro, regardless of the size, but keep in mind that it won't be able to fully charge your 15-inch MacBook pro if you're using it constantly. If your laptop is asleep, it will slowly charge the device, but not everyone wants to have to stop using their MacBook in order to fully charge it. It'll charge the 13-inch version just fine.
While this might be a downside for some, it's worth noting how incredible this monitor is as a device: you can customize your monitor layout to have the perfect work environment with the help of a single, mess-free USB Type-C cable. The 4K display is ideal for both gaming and editing through photos and videos, and If you're looking for a quality monitor, LG is always a great direction to head in.
Take a peek at this other LG monitor...
We would recommend taking a look at something like the LG UltraFine 5K instead: not only is it a terrific product, but it also will work with both sizes of MacBook and charge them effortlessly. The only downside? It's a little more expensive, but you do get that peace of mind that your MacBook pro is charging when you're using it.
The worst part about the UltraFine 5K? The price tag, but the UltraFine 5K is also built to work with both the 13- and 15-inch MacBook Pro, developed in partnership with Apple. With a resolution of 5120x2880, you'll have a hard time seeing any pixelation on the 27-inch IPS display, which also features excellent color range thanks to its support for the Display P3 color gamut.
Our pick
Beautiful, bold, affordable
Not only does this monitor have Color Calibration Pro and effortless personalized split screen 2.0, but this particular monitor works with both your 13-inch and 15-inch MacBook Pro.
This beautiful 4K UHD monitor from LG is bound to have you falling in love with working at your desk again. Just note that it won't be able to fully charge your 15-inch MacBook Pro.
More Compatible
A bit more expensive but totally worth it
If you're in the market for a high-quality, highly-rated monitor from LG that works with both sizes of MacBook Pro and can keep them charged, then we recommend taking a look at the LG UltraFine 5K.
While this monitor is quite a bit more expensive than its LG 27UD88 monitor sister, it is worth noting that it has a stunning 5K display and additional USB-C ports, making it ideal for efficient work, whether you're organizing documents at the office or family photos at home.
Forever our favorite
Can do just about everything
Whether you're someone who wants to edit movies and photos on the go, someone who needs a reliable computer for school or business, your MacBook Pro has you covered. You can either pick out your MacBook Pro in 113-inch or 15-inch sizes, but keep in mind there is a substatial price difference between the two.
Pick out your MacBook Pro in silver or space gray aluminum, turn on that retina display, turn on that 2.2GHz - 2.6GHz dual-core 7th-generation Intel Core i5 processor, and see how this new piece of tech can change your life for the better.
