Act quick and snag the AirPods Pro at almost $60 off right now via Amazon
Apple's popular noise-cancelling AirPods Pro aren't among the most affordable options when it comes to true wireless earbuds, though thanks to a limited-time sale at Amazon, now's the time to buy if you've been waiting for a great AirPods Pro deal. While supplies last, the AirPods Pro are on sale for just $189.99, saving you nearly $60 off the regular cost of $249. Today's deal brings these earbuds down to one of their lowest prices in history, and it likely won't last for long at this price.
The popular noise-cancelling true wireless earbuds by Apple are now discounted by $59 at Amazon while supplies last. These earbuds come with a charging case that lets you listen for more than 24 hours while you're on-the-go.
The AirPods Pro feature active noise cancellation to block out any ambient and background sounds around you so you can focus on your music, calls, or whatever's playing in your ears at the time. They also feature a transparency mode which allows you to filter back in all those sounds in case you do need to hear what's around you for a moment.
Another major upgrade that the AirPods Pro have over the standard AirPods is improved water-resistance and sweat-resistance, making them a much better option to wear to the gym or out for a run — even in the rain. We even ran a 5K with the AirPods Pro to see how they'd hold up and they did great.
These are in-ear earbuds as opposed to the standard AirPods design. You'll receive three sizes of soft, silicone tips to help adjust the earbuds for a better fit. There's also a notable feature which uses adaptive EQ to tune your music to the shape of your ear automatically, providing customized sound for each user and ensuring you have the right fit.
The AirPods Pro are easy to setup with all Apple devices, and they can be used with non-Apple devices using Bluetooth as well. Apple device owners will likely have the best experience with them though, with easy pairing and device switching, hands-free access to Siri by saying "Hey Siri", touch controls, and more. The case that the AirPods Pro earbuds come in is also capable of charging wirelessly and can keep the earbuds powered up on-the-go for more than 24 hours.
Our guide to everything you need to know about the AirPods Pro has more in-depth information if you're looking to know more and we've also gathered up all of the best AirPods deals if you're not looking for the Pro model.
