Baseus has three powerful charging solutions to juice up nearly any device anywhere
If there's one thing to be sure of these days it's that people won't run out of things to charge anytime soon. As desks and backpacks become more cluttered and devices continue to fight between power and portability, trying to keep everything juiced up to avoid the all-too-real battery anxiety is an extra stress no one needs right now.
Baseus has been making high quality chargers and accessories for over 10 years and it has three unique charging solutions that fit everywhere your devices do.
The first one is the PowerCombo 65W Hybrid GaN Power Strip capable of charging 6, yes 6, devices at one time.
This charger has 2 USB-A, 2 USB-C, and 2 full sized AC power outlets which means it can charge almost any device that could conceivably end up on a desk. While the 65W may not handle the highest end, most power-hungry laptops and desktops, most of the mainstream ones should be just fine.
With all those ports, it's perfectly capable of charging the new MacBook Air, the upcoming iPhone 14, an Apple Watch, an iPad, AirPods, and your partner's iPhone all at the same time. And the 2 full-sized AC ports on the sides can also handle monitors, a PC, or nearly any other device you might need to plug in which means the days of having multiple chargers cluttering up your desk are over.
Prime members can take 53% off the PowerComb 65W GaN Power Strip during Prime Day, which brings it down to a compelling $47.99.
While out on the go, the 100W USB-C laptop power bank is great for juicing up a laptop or really anything else. It has 2 USB-C ports certified for Power Delivery 3.0 and the 100W output is capable of boosting a MacBook Pro 16 inch to 36% in just 30 minutes. There are also 2 30W USB-A ports on the power bank which is perfect for fast charging the new iPhones coming out later this year.
In total, the 4 available ports on this power bank make it easy to keep everything charged up no matter where you are and the 20,000mAh capacity ensures you won't run out of juice before making it back home. There's also support for two-way fast charging so when you really need some extra juice, you can plug it into a wall charger to get an extra boost.
Most other power banks with this high capacity are large and bulky but this power bank is incredibly thin and light. At just 0.7 inches thin, it's 50% smaller than most regular 20,000mAh power banks. Amazingly, Baseus was able to fit an LED status screen on this super thin and light device which gives an always-updated status of the device's charge time as well as how much juice is left in the tank.
On Prime Day, the 100W power bank will be 50% off meaning you can pick one up for $79.99.
If you don't need that much power while out adventuring, Baseus has a smaller, 10,000mAh MagSafe battery pack that's a perfect companion for the iPhone 12 and 13 series - and presumably the new iPhone 14 lineup as well. Just snap it onto the back of any MagSafe compatible device and it will wirelessly charge at 7.5W.
But wait, there's more. Baseus also included a USB-C and USB-A port on this battery pack, both offering 20W charging speeds. The 10,000mAh capacity means you can charge an iPhone twice or charge an iPhone, some AirPods, an Apple Watch, or another iPhone all at the same time.
The Megattach 20W Magnetic Power Bank will be 37% off during Prime Day so pick one up for $31.99.
