The Belkin Max Sleeve for iPad not only does a great job of protecting your iPad, but it gives you a little extra room to stick some of your accessories in as well. The case is made of a fabric material that is pleated on the front. This is what allows you to have a zipper compartment in the front to stick your other gadgets in.
The inside of the case is a foamy white mesh material. It's extremely soft so you don't have to worry about it scratching your iPad. It's also a loose fit, which means you won't damage your iPad while taking it out and putting it back in the case. There's always a down side to a case not fitting snugly though, and that's if you forget to zip it and pick up the case by the wrong end, it's very likely your iPad could go crashing to the floor. We didn't have this happen with this case, but I could see that being a problem as the material on the inside doesn't offer any grip.
The way we cast that fear aside was to put a silicon case on the iPad and then put it in the Belkin Max Sleeve. The silicon provides the grip and solves the issue. I know a lot of people wouldn't want to buy 2 cases so it isn't an ideal situation. My advice? It's a great case worth the money, just be careful how you pick it up, or make sure you always zip it up.
Other than the sliding out of the case issue, this is a great case and well worth the money. It offers superior protection in an unobtrusive form factor. Even though it's small, it still lets you stow away other objects, which is nice. If there's any girls out there like me that hate carrying around a laptop/iPad bag and a purse, this is awesome. Simply throw your phone, credit cards, etc in the front pouch and you're good to go. You can purchase the Belkin Max Sleeve for iPad from the TiPb Accessory Store.
- Allows for extra storage room in the front pocket
- Material on the outside is easy to grip on to
- Material on inside won't scratch your iPad
- Inside material is a little slick so forgetting to zip up could cause an iPad to fall out
- Zipper on front pocket is sometimes a bit hard to pull
