Best battery cases for iPhone 13 Pro Max in 2026
Your iPhone 13 Pro Max already has a huge battery, but you can extend battery life further with a battery case.
With the iPhone 13 Pro Max, once Apple's largest handset and still more than up to the task of being your phone of choice, you get 28 hours of video between battery charges. If that's still not enough for you, or if your battery health isn't what it used to be, you may want to invest in a battery case. While these tend to add even more heft to what is already a large phone, it can be worth it to keep you happily tapping without fear of it dying on you.
Here are some of the best iPhone 13 Pro Max battery cases, with every use case and budget taken into consideration.
Quick List
Best overall
Just check out the Amazon ratings on this one, it's a popular choice. On the slimmer side, it won't weigh down your pocket or bag. With 7000mAh, you'll get enough power to get you through even your busiest days.
Best for battery
With a massive 8,500mAh battery built in, this case promises to double your iPhone 13 Pro Max battery life. This case is made of rubber and polycarbonate, features a raised bezel design, and is MagSafe compatible. In addition, the case is compatible with Apple CarPlay and offers advanced sync-through technology.
Best on a budget
This budget case includes a 4,800mAh battery and supports Qi wireless charging. It consists of a soft rubber case with a hard shell plate to protect your handset, but its design is still slim and portable. Unfortunately, the case won't work with CarPlay.
Best for protection
The California-designed case includes a 6,500mAh battery and supports wireless and wired charging. It also ships with one tempered glass screen protector, which will protect your iPhone 13 Pro Max from scratches and saves you buying one separately.
Best for color options
If basic black bores you, check out this colorful pick. It comes in both the red shown here and a pink option. With 8500mAh, this slim and protective case will last all day and then some. Like the others on this list, the LED lights indicate the amount of power you have left.
Best alternative solution
Just hear me out. Since your phone has MagSafe, consider using a MagSafe-compatible iPhone 13 Pro Max case and a MagSafe battery like U by UAG Power Battery. I reviewed it and found it so easy to pop on and off as needed, preferable to keeping the iPhone in a heavy case all the time. It's become a fixture in my travel bag.
Q & A
Which battery case should you buy?
While the larger handsets like the iPhone 13 Pro Max have bigger and better batteries than their smaller counterparts, this model is getting older and your battery health may have declined a bit. It's worthwhile to invest in a portable battery case if you find yourself away from your charger for hours or even days at a time. The AFTRYOUGO Battery Case for iPhone 13 Pro Max comes highly recommended for its reliability and powerful 7000mAh battery.
However, I'm personally not into battery cases. I find them a bit unwieldy, making the iPhone heavier and more awkward to hold. Since you really only need them when your phone's battery is getting low, they may not be ideal to use all of the time. In my own personal life, I use a regular MagSafe case and pop on a MagSafe battery pack when I need some extra juice. I've tested out a number of them, and the U by UAG Power Battery is the one I'm most likely to grab on my way out the door for a long day of exploring. It comes in several colors and has a handy kickstand/phone grip on the back for video viewing, FaceTime, and selfies.
