Best Accessories for Apple AirPods 2021
Apple's AirPods are a magical accessory that complements all iPhones, iPads, and Macs. They're super intuitive to connect to your devices, and all you need to do to control them is tap or swipe on them to control playback. But they're expensive, so you'll want to protect your investment or even improve their fitness or staying power while you take them on a run. These are some of the best AirPod accessories you can buy.
Premium leather
Twelve South is a trusted name in Apple accessories, and the AirSnap is another fantastic product. It's a small, stylish leather case that acts as a leather shield for your AirPods. An opening on the bottom lets you charge without taking it out, and the small keychain lets you clip it anywhere. The metal snap on the case means your AirPods aren't going anywhere.
Better fit
These EarBuddyz covers are soft and made of silicone. They go over your AirPods and provide a comfy, secure fit, so no more worrying about those AirPods falling out of your ears! The only drawback is that the AirPods can't charge with these on, but they slip on and off quickly and easily.
Strap it on
The Spigen TEKA RA100 AirPods Strap is made of a flexible and durable TPU material that's soft to the touch. The strap holds the AirPods together and goes around your neck when not in use. This is great for those who like to go running and listen to music at the same time.
Customize and protect
Your AirPods are expensive, so you should protect them while adding a splash of color. Airpod Skins are vinyl skins that are easy to apply and remove. They'll protect your AirPods from everyday wear, tear, and scratches while also looking stylish. Plus, with the brighter colors, it's less likely that you'll lose them.
Ultimate protection
This premium Catalyst case is made of impact-resistant, scratch-proof, rugged polycarbonate with light silicone, so it can take pretty much anything you throw at it. The Catalyst case is also waterproof, so you don't need to worry when you're outdoors. It also includes a detachable carabiner, so you can clip it anywhere.
Slim leather
If you love the leather look but don't want to add extra bulk to your AirPods case, try Vinyl Design. It's a hardshell case that perfectly fits your AirPods and is covered in tanned leather. There's a cutaway for the charging port, and it comes in black, red, dark brown, and light brown.
Classic leather
Leather is always in style, and therefore, so is this Fintie leather AirPods case. There are several different colors and patterns to choose from, and the premium leather materials provide an elegant and luxurious look for AirPod protection. The case has a magnetic clasp, so you'll always have easy access to your AirPods, and they can clip anywhere with the attached keychain.
Simple protection
If you just want some basic scratch protection, check out the PodSkinz AirPods Case. It's a soft-touch silicone case that adds minimal bulk and protects your AirPods charging case from everyday bumps, drops, and thumps. Plus, you can't beat the affordable price.
Best charging stands for your AirPods 2 and iPhone 2024
All inclusive
The STM ChargeTree Swing 3-in-1 Wireless Charging Station does it all, as we noted in our review. It features a classy design and tiny footprint, with the ability to charge your iPhone wirelessly in front and your AirPods wirelessly behind it. If you want to charge your Apple Watch, too, just swing out the arm and charge away.
Charge everything
If you have an iPhone 12 or newer, consider this thoroughly modern MagSafe accessory, the 3-in-1 Belkin MagSafe Charger. This stunner, which we loved when we reviewed it, charges your iPhone, Apple Watch, and AirPods all at once.
Bargain choice
This little gem lets you charge your iPhone wirelessly, as well as your AirPods with the regular (not wireless) charging case and Apple Watch. Note that the wall charger is not included, so you will need to provide your own.
Two phones plus
This handy charging stand lets you charge your AirPods 2 along with up to two iPhones (or other smartphones) and your Apple Watch (using your own puck). You don't need to have the wireless charging case for your AirPods 2, as this stand has a hole for you to insert your AirPods charging cable.
Great for travel
This nicely priced stand lets you wirelessly charge your iPhone, AirPods 2, and Apple Watch. It adjusts to four different angles and can be folded up and tucked into your bag for travel.
Double duty
If you have the wireless charging case for your AirPods, then chebeenly's offering lets you charge your iPhone and your AirPods together. It's actually two pieces that attach magnetically. The upright stand also enables you to charge your iPhone in a raised position, either vertically or horizontally, so you can watch videos or FaceTime with ease.
Best for most
Apple's wireless charging case is the standard. It looks and feels just like the case in the box, and works exactly as you would expect. You might pay more for it, but you'll get the best wireless charging AirPods case. Hands down.
Colorful options
As long as you're replacing your AirPods case, there's no reason you have to stick with white, right? This one comes in four colors: light green, purple, black, and white.
Powerful
Another wireless charging replacement case with some colorful options, CIVPOWER'S can get you three hours of listening time from a 15-minute charge. A full charge to the case will get you five AirPods charge-ups.
Lookalike
The Chillyfar Wireless AirPods Charging Case looks a lot like Apple's, and it functions in much the same way. Just pop in your AirPods, and then place the case on any wireless Qi charger.
Best cases for AirPods 3
Best overall
This shock-absorbing silicone case gives your AirPods 3 complete coverage while maintaining MagSafe compatibility. A cutout for the LED light lets you keep track of your charging status. It comes with an attached carabiner clip for added convenience on the go. Choose blue or black.
Gamer's choice
How fun is this? The elago AW5 AirPods 3 Case resembles a favorite retro hand-held gaming device. You can still see the LED charging light and charge your AirPods wirelessly within the case. Choose from three different color options: light grey, black, and Sand Pink.
What's your sign?
If you're into horoscopes, you'll want to check out this AirPods 3 case. This sturdy case has a picture of your sign on the front and your sign's name and constellation on the back. Wireless charging isn't affected. Choose from all 12 horoscope signs.
Colorful choices
Get drop protection with this premium silicone case that's three millimeters thick and comes in tons of colors. It's soft, scratch-resistant, and washable. The LED light remains visible, and wireless charging will still work fine within the case.
Tough choice
Get a little more protection with this tough armor case from Spigen. Extreme impact foam dissipates shocks for internal protection, and the lines on the front help improve grip to prevent drops in the first place. The case lets you charge wirelessly, and the LED charging indicator light is fully visible. Choose from several colorways.
Rugged
The anti-slip design and military-grade drop protection mean peace of mind. The case doesn't interfere with wireless charging, and the LED charging light is fully visible. The case comes in three colors, each with a matching carabiner clip: blue, black, green, and purple.
Glam
Give your AirPods 3 a decidedly glamorous look with this marble-inspired case that comes in several colors. The metal trim glams it up even more. The shock-resistant body and included wrist strap add protection and convenience. Wireless charging will still work with this case on.
Stony exterior
This case has a uniquely modern stone look. However, the case is actually made from PC (polycarbonate) and TPU (thermoplastic polyurethane). The LED light is showcased, and wireless charging will still work on your AirPods 3 within this case. The attached wrist strap adds another interesting design element.
Yummy
This adorable novelty case looks like a tiny ice cream bar with sprinkles that come in several mouth-watering "flavors." The durable premium silicone case supports wireless charging, and a small carabiner clip is attached to the stick.
Clear bargain
If you're looking for protection but not really looking to change up the look of your AirPods 3, check out this totally clear design from RESTONE. The microdot texture prevents the wet look, and the round, gold-tone ring sets it apart. It also comes in several colorful, clear tints.
Sophisticated
The PC and fabric design gives your AirPods 3 a more sophisticated air while also protecting them from drops and bumps. A soft microfiber interior protects from scratches and you have a few color options. Wireless charging still works, and the LED light is fully visible within the case.
Best AirPods Max cases
Great protection and value
The co2CREA Hard Carrying Case is shockproof, dustproof, and water-resistant so that it will protect your AirPods Max from drops, splashes, bumps, and dust. You can carry your case with the included hand strap, and it features space for chargers and other accessories.
Hard shell and waterproof
The VOMA Leather Case is made of waterproof leather and has an EVA hardshell exterior, which will protect your AirPods Max from drops, dust, and water. In addition, it has an interior removable mesh pocket to store your accessories and a handle for easy carrying.
Premium leather style
The BlackBrook case is made from premium-grade leather and has a classic look. You can store your AirPods Max and also have access to charge them right in the case. This case also has magnets, so you can put your headphones in low power mode when inside.
Automatic sleep mode
The Yinke case automatically will set your AirPods Max into sleep mode. It's a hardshell case with a shockproof, waterproof, and scratchproof design. There is also room for your charging accessories.
Not a case
The Spigen Ultra Hybrid PRO is not a case but a cover to provide additional protection to your AirPods Max if you like the case shipped with them. They cover the outer cups of the headphones to protect against daily damage and scratches. The covers are clear plastic, so your AirPods Max keeps their original look.
Best AirPods Pro wireless chargers
Magical magnets
Apple's MagSafe Charger is designed to work with the iPhone 12 and 13 series. Still, it also works for your AirPods Pro, especially if you have the updated MagSafe charging case. In our review, we loved how the MagSafe Charger snaps into the perfect charging position, as well as its 15W charging speeds, making it one of the fastest wireless chargers.
Affordable AirPods charging
Anker is a trusted brand and one that we recommend over everything else when it comes to affordable charging. This simple, non-MagSafe charging pad provides between 7.5W to 10W of power and will work with AirPods Pro wireless charging cases.
All-in-one
If you have all the Apple things, you can't go wrong with Belkin's all-in-one charger. Belkin's charger outputs at up to 15W and has unique arms for your iPhone and Apple Watch, with AirPods Pro going on the base. During our testing, we really liked how the Belkin BoostCharge Pro 3-in-1 Wireless Charger made topping off our devices seamless, plus it just looks great sitting on a nightstand or desk.
Fast simplicity
This sleek and compact wireless charger from mophie has a maximum output of 15W, so you get fast charging for your AirPods Pro and iPhone. It will look great on any desktop, and it is also the perfect size for traveling.
Boost up
This 7.5-watt charging pad from Belkin features an extra-long six-foot cable with a strap and a 20-watt power supply. In our testing, we found that the Belkin Boostcharge Magnetic Portable Wireless Charger Pad's included strap really makes a difference when it comes to portability — so much so that it has become our go-to charger for travel.
Multipurpose charger
The Anker MagGo 633 is a 4-in-1 MagSafe charger that charges your MagSafe iPhone and AirPods Pro, acts as a stand for your iPhone, and has a detachable MagSafe battery pack. It's a little pricey but in our hands-on review, we found the Anker MagGo 633 to be well worth the cost for everything it does.
Best chargers for AirPods 2
Quality we trust
Anker is a brand a lot of us trust, and their Qi-certified charging mats are no different. This particular one provides Fast Charging when plugged into a compatible charger, and it has LED light indicators to let you know in a glance how charged up your devices are. It's super slim and barely takes up any space, making it a perfect nightstand companion for your iPhone or AirPods 2.
3 chargers in 1
The Apple Watch edition Base Station by Nomad is the perfect charger for those of you who own a Qi-supported iPhone, an Apple Watch, and AirPods 2 with a wireless charging case. There's a spot for each one! Who needs AirPower when you've got something this good? It's iMore Managing Editor, Lory Gil's favorite wireless charger and it's easy to see why.
Quality Lightning cable on a budget
The AmazonBasics line is always affordable and has pretty decent quality stuff. The Nylon Lightning cable is no different. It comes in 3 or 6-foot lengths, and a nice selection of colors. The nylon is also braided, so it's more durable than Apple's own standard Lightning cable. And for the price, it's definitely not a bad pick.
High-quality cables
Anker is a trusted name when it comes to mobile accessories, and the Powerline+ II is no different. This cable is heavy-duty with a nylon braid that can withstand 175 lbs. and 30,000 bends. It comes in several lengths, including 3, 6, or 10-foot varieties, and has a nice selection of colors.
Just the basics
If you don't like the braided nylon cables and just want something that's affordable and plentiful, then give the basic AmazonBasics Lightning to USB A cables a try. They're similar to the default Apple ones for a fraction of the cost, and you can pick them up in a variety of colors and lengths. Best of all, they come in multi-packs, so you can stock up and save.
Turn some heads
This unique charging pad is super small, so you can take it with you anywhere for a quick juice up. The exterior is wrapped in a fabric material to give it a distinctive aesthetic that is sure to turn heads, and it comes in a few classy colors. It's capable of fast charging up to 7.5W for capable devices, and your AirPods 2 are sure to go from zero to 100 in no time at all. A status light indicator lets you know whether your devices are charging properly too.
Prop it up
If you want a wireless charging pad that stands upright, then look no further than the Anker PowerPort Stand. This charging mat sits at an angle so you can have your iPhone at a comfortable viewing angle, or you could even check the status light on your AirPods Wireless Charging case without having to twist your neck. An LED light on the front also tells you if it's charging properly or not.
All-in-one bundle
Most of the options we've mentioned don't come with an AC adapter. This option from RAVPower includes the AC adapter, so you don't need to go grab a separate one. This charging mat comes in a few color combos, including a nice black and red, and an LED light on the front lets you know if the device is charging properly. It's capable of fast charging up to 7.5W for compatible devices. This is a great bundle for your AirPods 2, and other Qi-certified wireless charging devices.
Classy design
Mophie is well known for its batteries and charging accessories, and the Charge Stream Pad+ is no exception. This wireless charging pad has a minimal design that is still classy and elegant, and it can provide up to 10W fast charging to compatible devices. It's fairly small in size and has a non-slip grip to keep it on your table. And it can charge through cases up to 3mm thick, in case you want to use it for your iPhone with a heavy-duty case.
Best ear hooks for AirPods 3
Just the basics
These simple ear hooks do the job. The wingtip slides comfortably into the cartilage of your ear, making a more secure fit for your AirPods 3. You get four in a package (all white, all black, or half and half) so you'll have plenty of spares in case you lose them.
Two-pronged
If the typical single-pronged style isn't for you, check out this two-pronged style. These ultra-soft silicone tips may fit your ear more snugly and comfortably. These come with their own storage pouch, so you won't lose them when you're not using them.
Model agnostic
Since these over-the-ear ear hooks attach to the AirPods' stems as opposed to the earbuds themselves, they will fit previous models and possibly future models, too. Plus, they come in some fun colors.
Nice price
Get four pairs of over-the-ear ear hooks for one low price. Since they hook onto the AirPods stems, they will fit any model that has them.
Two different styles
Can't decide if you'd prefer the in-ear or over-the-ear style? Get two of each with this set. The in-ear style is a custom fit to the AirPods 3, while the over-ear style will work with just about any stemmed earbuds.
Around your neck
If you don't like the feeling of ear hooks in or on your ears, you might consider a strap like this instead. If your AirPods 3 do fall out of your ears, at least they won't drop to the ground or get lost. When not in use, your AirPods 3 can rest around your neck; the magnets form a necklace that stays in place. Choose from a bunch of color options.
Best Headphone Stands for AirPods Max
Shape-preserving support
Created specifically for high-end headphones like the AirPods Max, the Zero Infinity headphone stand supports headphones with a round shape that echoes the shape of a head. This preserves the shape and integrity of the headband when the headphones are not in use. The simple design will easily fit into the look of any office space.
Best for black AirPods Max
The gold and black design of the Omoton stand will look especially striking when paired with black AirPods Max. The adjustable stand can hold your headphones higher or lower depending on your preference, and it's easy to assemble or disassemble as necessary.
Best for tight spaces
If you don't have a lot of extra desk space, the Anchor Pro is an easy solution to keep your headphones safely tucked under a desk or table. Because of strong 3M adhesive, no drilling is required to install it, and the Anchor Pro includes cable management for easy charging.
Upgrade pick
For big budgets and expensive tastes, the Grovemade wood stand is beautifully crafted from solid hardwood, natural vegetable-tanned leather, and stainless steel. It will make the perfect accent to upscale office spaces.
Best for gamers
The Znoble headphone stand doubles as both a headphone stand and a connection hub for all your devices. It can charge the headphones and other devices using both USB 3.0 and Type-C ports, and it can also connect to laptops using the AUX port or silicone connection cable.
Wireless charger included
Another multifunctional stand, the New Bee stand works beautifully as a minimal headphone stand, and it will charge Qi-enabled devices as well. Charge your iPhone, AirPods, or any wireless charging device on the base.
Bottom line
Well, there you have it — accessories for your accessory. The AirPods may feel like a complete package already, but there are ways to make it more worth your purchase. You can either replace the case or make the AirPods more comfortable for you.
We definitely recommend the Twelve South AirSnap case because the company always puts out high-quality products, and this one is no exception. The fine leather feel and convenient utility of the little case are a perfect combination.
You can also sport-ify your Airpods with some Earbuddyz that will keep them from slipping out while you're running. Protect your AirPods and charge them in style with these great AirPod accessories!
