Best HomeKit air quality sensors in 2025
These HomeKit-enabled air quality sensors help you ensure you're getting the cleanest air possible in your home.
Monitoring the air quality in your home is one of a myriad of ways that a smart home can improve your quality of life and even your health. By monitoring your home for volatile organic compounds (VOCs) with one of the best HomeKit air quality sensors on the market, you can reduce the concentration of harmful, carcinogenic air pollutants in your home. Harnessing the power of HomeKit, these life-saving devices can alert you to poor air quality with an iPhone notification, and can be controlled using nothing but your voice with Siri. They'll show you how the levels of VOCs can change in your home from day to day, and how activities like cooking can bring down the quality of the air in your home.
A smart HomeKit air quality sensor is the natural companion of the best HomeKit air purifiers on the market, with automation enabling a system that automatically cleans the air in your home when it drops below a certain threshold. Here are our top picks for a smart HomeKit air quality sensor.
Make sure you're breathing in the best air with a HomeKit air quality sensor
Quality design
Eve's indoor air quality monitor features an industrial design complete with an E-Ink display. This portable monitor lasts up to six weeks on a single charge, and it also includes temperature and humidity monitoring. Thread and Bluetooth connectivity enable a quick and direct HomeKit connection without a hub.
Cost-effective
While it requires an Aqara hub, the Aqara TVOC Air Quality Monitor is still an incredible value with an E-Ink display that impressed us in our recent review. Aqara's sensor monitors VOCs, temperature, and humidity in an incredibly compact frame that runs for up to a year on a coin battery.
All-in-one
This sensor from Qingping is not only an air quality monitor but it also serves as a digital clock, making it perfect for bedrooms. An on-device OLED display scrolls through the current time and measurements for CO2, temperature, humidity, PM 2.5, and PM10. This sensor even includes a rechargeable battery so you can take it from room to room.
Inside and out
The Netatmo Smart Weather Station is the only HomeKit air quality sensor that can monitor air quality inside and out. This two-piece set includes an indoor module that tracks CO2, temperature, and humidity and a weatherproof outdoor monitor that gives you a local weather report.
Monitors and cleans
The Smartmi P1 is one of the few HomeKit-enabled air purifiers on the market, but it includes many extras to match the price. In our hands-on review, we loved how this purifier monitors your home and automatically ramps up fan speeds to clean quickly if the quality drops. Smartmi's cleaner also puts all of its measurements and speeds just a glance away thanks to its on-device display.
Smoke and CO
The First Alert OneLink Safe and Sound may look like an ordinary smoke and CO detector, but it has an AirPlay 2 compatible speaker for whole-home audio. Of course, this monitor also includes smoke and CO detection with a built-in alarm, and both are capable of sending notifications to your iOS devices when something is awry.
Monitor the situation with the best HomeKit air quality sensors
The best HomeKit air quality sensors are the quiet protectors of your home, silently measuring for dust, pollen, VOCs, CO2, and more. Once your device is up and running, it can work with tons of HomeKit accessories such as smart plugs that can turn on an air purifier if the air in your home becomes an issue. Siri support allows you to summon a brief report, with the virtual assistant replying with easy-to-understand responses such as "good" or "bad."
We love the Eve Room for its beautiful design and its portability. This fantastic monitor includes an E Ink display with customization options to make the metric that matters the most to you at the forefront. This sensor also features a built-in rechargeable battery that lasts up to six weeks, and it supports Thread — the latest and greatest connectivity standard.
Need an air quality sensor that works both indoors and out? Then the Netatmo Weather Station is the one for you. This healthy helper supports air quality, humidity, and CO2, plus it gives you a local temperature report when placed outside of your home. Whatever sensor you choose, you will gain valuable insight into what is floating around in your home.
