Best HomeKit Door and Window Sensors in 2025
A HomeKit door or window sensor isn't just a safeguard for peace of mind. The best ones can be combined with any number of Apple smart home devices to ensure that your home is always heated or cooled to your comfort and secured to its fullest extent. A HomeKit door or window sensor can detect when your doors and windows are open, delivering notifications through the Home app. Not only can this alert you to potential break-ins and intruders, but it can also be used to ensure you're not heating (or cooling) your home inefficiently while your windows and doors are open.
Know when your windows and doors open with these HomeKit sensors
Back to the top ^
FAQ
What does a window or door sensor do?
A window or door sensor for HomeKit connects to your home hub, attaches to a door or window, and then tells you when the aperture is open. This can be excellent for security purposes, letting you know what's happening around your house while you're not there.
Open and shut
HomeKit door and window sensors are an easy to install way to report on the status of your home. These sensors provide instant notifications when their status changes, and even work with other HomeKit accessories, enabling powerful automations. We love the Eve Door & Window sensor for its fast response times, and modular design, allowing it to function even if your surfaces are not in the best shape.
Need a solution for your outdoor gates? Then check out the ismartgate Wireless Magnetic Sensor. This weather-resistant sensor can save you a trip outside by letting you know whether or not you left it open again. Regardless of the one that you choose, the best HomeKit door and window sensors will always let you know what is going on in your home.
Are you looking for more Homekit accessories? Consider our list of the best HomeKit products of the year.
Christopher Close
