Best HomeKit power strips 2022
Power strips are a household essential, and with the best HomeKit power strips, things are taken to the next level. Combining the utility and security of power strips, with the magic of Siri, scenes, automations, and of course Home app controls, these smart options are one of the best HomeKit accessories to have on hand. We have gathered all of the best HomeKit power strips around to help you decide which is the best for your needs.
Beauty & brains
The Eve Energy Strip takes the classic power strip and combines it with gorgeous styling. This aluminum frame strip is generously spaced between each outlet, perfect for accommodating bulky plugs, and each outlet works independently. Eve's power strip also has overcurrent, overvoltage, and surge protection built-in, keeping your devices safe and sound.
USB convenience
VOCOlinc's PM2E power strip packs in three smart outlets and two USB ports, making it highly versatile. Each outlet can handle up to 1800 watts, and the USB ports can output 2.4 amps each, perfect for phones or tablets. This power strip also has status LEDs on the device itself, letting you know which outlets are on with just a glance.
Monitor everything
Koogeek's Smart Power Strip one-ups some of its competition by providing energy monitoring capabilities for all three onboard outlets. In addition to its three smart outlets, this strip includes three USB ports, two for lower power for iPhones, and one with higher output for an iPad. Koogeek's strip also handy LED indicators, separate power buttons, and wide spacing.
No hub required
The Incipio CommandKit Smart Power Strip connects directly to your home network via Wi-Fi without the need for an additional hub. Each outlet works separately through Siri or the Home app and can also power on and off with on-device controls. This power strip also features a flat end plug, making it able to fit into tight spaces.
Quick charge
The PM2 from VOCOlinc looks almost identical to its cheaper cousin, but this strip has one additional USB port. This extra USB port is special, as it can deliver Quick Charge 3.0 rapid charging to devices that support the standard. The PM2 also includes energy monitoring through VOCOlinc's app, but this only applies to one specific outlet.
For the outdoors
The Meross Outdoor Smart WiFi Plug brings the convenience of power strips to the great outdoors with two weather-resistant outlets. Each outlet can be individually controlled through Siri and the Home app, and since it connects to the home network via Wi-Fi, it has great range, easily lighting up the areas outside the home all year long.
Power up with the best HomeKit power strips
The best HomeKit power strips offer the ultimate in convenience, utility, and protection, all in a compact and familiar package. Once set up with HomeKit, these power strips can work with your favorite scenes and automation, making things come to life or shut down with just a tap.
The Eve Energy Strip provides all the HomeKit smart home goodness with a simply beautiful design. Don't let its looks fool you, though. This power strip packs in tons of safety features such as surge, overvoltage, and overcurrent protection.
Need a power strip that has lots of USB ports and quick charging capabilities? Then the VOCOlinc PM2E might be the one for you. This smart strip covers all the basics and includes those precious QC 3.0 ports, perfect as a bedside companion.
