Best HomeKit switches for ceiling fans in 2025
HomeKit switches have been around for a while now. However, did you know you can use them to control your ceiling fan? Most simple on and off switches allow your fan to join in on the HomeKit fun — and they're easy to install, just like a light switch. In addition, some controls can even adjust your fan's speed. We've gathered the best HomeKit switches for ceiling fans to take your smart home to the next level.
Cool off with smart ceiling fan switches
Back to top^
HomeKit switches for ceiling fans are a great way to get the air moving in your home. Automation can keep your air moving throughout the day, preventing it from becoming stuffy, and speed adjustments provide the ultimate convenience.
We love the Lutron Caseta Fan Speed Control for its ability to set fan speeds without pulling a chain that could be hard to reach. This switch can crank things up instantly using the Home app or your voice using Siri when things get a little hot. Combined with Lutron's legendary reliability and responsiveness, this fan switch is one of the best HomeKit accessories around.
Want a switch that allows you to control your fan and light separately? Then consider the Aqara's dual-rocker Smart Light Switch, which offers two independent buttons in one easy-to-install package. Just remember that it requires an Aqara hub to make all of the magic happen.
Christopher Close
