Best iPhone 11 Pro Max Cases in 2022
iPhone 11 Pro
iPhone 11 Pro (Image credit: Rene Ritchie/iMore)
If you're looking to get the new iPhone 11 Pro Max, there's a lot that goes into maintaining the device. The phone is going to be expensive, so you want to make sure that nothing happens to it. That's why you should get a case to protect it, and we made sure to pick the best of the best. We've found some great cases that are available for the iPhone 11 Pro Max so that you can protect it from day one.
Protect your new phone
Our all-time favourite is the Totallee Thinnest Cover case. It's protective, it's incredibly thin so it feels like you have no case at all, and it works with wireless charging. It's everything you would need in the perfect case.
If you want something simple, but adds some flair to your device, we recommend a GVIEWIN clear design case . The clear ones with a print design are cute and still show off your phone colour. They also perfectly protect your phone, so you won't have to worry about hurting your phone. Also, GVIEWIN cases hold up well over time.
For those who want a nice splash of colour while still showing off the phone, we would recommend checking out the Catalyst Impact case. It's clear, so you're still showing off your iPhone 11 Pro Max, but the pop of colour gives it a fresh look. It's a great choice if you're looking for something that's just a little bold.
Christine Chan
