Best HomeKit light bulbs to use for your home in 2025
Let there be (smart) light.
What sets the best HomeKit light bulbs apart from the rest? Well, the answer to that likely depends on what exactly you are looking for. While some work better on a much smaller budget, others focus on extra compatibility or a classic look.
The reason you want a HomeKit-compatible light bulb is that you can hook it up to the rest of your house to turn it on and off on the go, or set up functions and systems to work at specific times. For instance, you could connect it to your alarm clock app to slowly wake up as you do. You can also just control it from a distance, saving you from having to get up and flick the switch yourself. To fully kit out your room, you are going to want to pick up some of the best HomeKit light strips, one of the best HomeKit hubs to control them all.
In first place for us is Nanoleaf's Essentials A19 bulb, which has a great look to it and can get super bright. However, there are plenty of choices that may be better depending on what you are looking for.
These are the best HomeKit light bulbs you can grab right now.
Quick List
Simply the best
Nanoleaf's Essentials A19 light bulb features millions of colors, 1,100 lumens of peak brightness, and support for HomeKit Adaptive Lighting. That is only part of it, as this bulb works without the need for a hub with Bluetooth and Thread connectivity. While Bluetooth is great, we were blown away by the lightning-fast response times.
Affordable ambiance
As noted in our review of the meross Smart Wi-Fi LED Bulb, we loved how it gives you the convenience of HomeKit and Siri controls at a price that won't break the bank. This bulb tops out at a bright 810 lumens, supports a mix of 16 million colors, and since it uses Wi-Fi, you don't have to worry about setting up a hub.
Mighty and mini
The LIFX Color A19 is one of the smallest HomeKit-enabled smart bulbs on the market. Don't let the small size fool you, though — this tiny bulb pumps out 800 lumens of lighting bliss, equivalent to a standard 60-watt bulb. This bulb also supports millions of color combinations, covering just about any hue you can dream up.
Brightest of the bunch
Philips Hue is synonymous with smart lighting thanks to accurate color reproduction, fast response times, and excellent reliability. The latest 16-watt A21 Hue bulbs also happen to be the brightest HomeKit light bulbs on the market at a whopping 1,600 lumens of colorful goodness.
Vintage charm
Filament-style lighting has made a huge comeback, and what better way to welcome it back than by adding in some smart lights? Sylvania's Soft White Filament Bulb does just that by mixing in Bluetooth wireless with the beautiful stylings of the original light bulb design. This vintage look is gorgeous in any home and is one of our favorite smart bulbs on this list.
Dynamic colors
Yeelights's color LED bulb utilizes Wi-Fi, allowing it to connect to your home network with just a scan of a pairing code. It provides up to 800 lumens of multi-color goodness through the Home app and Siri, but for even more fun, the Yeelight app offers many dynamic scene options that make your home come alive.
Q&A
The best HomeKit light bulbs are ideal for smart home beginners as they're one of the quickest ways to upgrade and expand your smart home with very little cost or commitment. They're incredibly simple to use and once installed, you can just use Siri or your iPhone to turn your lights on or off. That goes for no matter where you are in the house too, so it's very flexible.
From there, you can get more creative with your HomeKit setup. That could mean adding on one of the best HomeKit cameras, or using one of the best HomeKit air quality sensors to ensure your home has the cleanest air possible. For bigger projects, there are always the best HomeKit security systems too.
In all cases, including the best HomeKit light bulbs, they will all work with the Home App. You can use it to create scenes and have the lights do certain things when certain parameters are met. For instance, you could schedule the hall light to come on after you unlock the door via one of the best HomeKit door locks.
What should you look for in a HomeKit lightbulb?
When buying smart light bulbs, it's important to consider compatibility. All the smart bulbs in this guide are compatible with Apple's HomeKit, but if you're looking for alternatives, you need to check they work with your current setup.
Matter compatibility is particularly useful. It's the new standard for smart home devices and it's backed by Apple, Google, Amazon, and many other big names. Matter is designed to increase interoperability between smart home devices across platforms. That means any accessory you buy with the Matter logo will be platform agnostic so if you ever want to switch away from HomeKit, you can.
It's also important to think about what features you need most. Some people may only need a smart light bulb with simple white and yellow shades of light, while others may prefer one with millions of colors. Predictably, the more features mean the more expensive the light bulb, so think about what your priorities are.
Our recommendations
If you want the best smart light bulb on the market, the Nanoleaf Essentials A19 Bulb is the one for you. This smart bulb has an incredible 1,100 lumens of brightness and can display millions of colors. The LED bulb utilizes Thread networking technology which offers lightning-fast response times and excellent reliability.
It's ideal to go alongside any HomePod 2, HomePod mini, or the latest Apple TV 4K in your home.
If you want to add smart capabilities without losing the vintage charm of a filament bulb, there are always Sylvania's gorgeous Smart+ bulbs. They provide the cool filament look while also offering Bluetooth functionality, so there's no need for a separate hub.
Whichever smart light bulb you go for, consider adding on a HomeKit light switch so you don't have to worry about wires or anything more than what you're already used to. While you're planning how to spruce up your home, consider adding on one of the best HomeKit ceiling fans. With the right set of shortcuts, you could even have it start the moment you turn a light on.
Daryl is iMore's Features Editor, overseeing long-form and in-depth articles and op-eds. Daryl loves using his experience as both a journalist and Apple fan to tell stories about Apple's products and its community, from the apps we use every day to the products that have been long forgotten in the Cupertino archives.
Previously Software & Downloads Writer at TechRadar, and Deputy Editor at StealthOptional, he's also written a book, 'The Making of Tomb Raider', which tells the story of the beginnings of Lara Croft and the series' early development. His second book, '50 Years of Boss Fights', came out in June 2024, and has a monthly newsletter called 'Springboard'. He's also written for many other publications including WIRED, MacFormat, Bloody Disgusting, VGC, GamesRadar, Nintendo Life, VRV Blog, The Loop Magazine, SUPER JUMP, Gizmodo, Film Stories, TopTenReviews, Miketendo64, and Daily Star.
- James Bentley
- John-Anthony DisottoHow To Editor
