The Best USB-C Battery Packs and Power Banks for iPad Pro in 2022
USB-C is quickly becoming the most popular charging port connection of new devices, including the iPad Pro. If you're constantly on-the-go, it's important to choose a portable power pack that supports USB-C charging. We've compiled a good list of the best USB-C portable charges and battery packs that are reliable, hold a decent amount of juice and are easy to take along anywhere.
The absolute best
This USB-C portable charger powers up your iPad Pro, laptop, cellphone or Nintendo Switch quickly and multiple times before needing to recharge itself.
Charge over and over
This top brand USB-C portable charger works with iPad Pro and MacBook. It holds enough power to charge three devices on one charge.
Power on a budget
This little power pack is compatible with everything Apple – iPhones, iPods, iPads. Its dual ports power up to two devices at a time.
Fast, powerful charge
This battery pack charges fast with 18W. It has multiple ports that are compatible with several devices, including the iPad Pro.
Certified for safety
This power pack comes with a USB-C adapter so you can easily charge devices with different connections. It is certified for safety.
USB-C + wireless
This charger has both a USB-C and a micro USB port, plus, using your phone's Qi ability you can use the Gnceei to wireless charge your device.
Our top pick and why
Our top pick for USB-C charging is the RAVPower pack. This charges your devices with 30W and holds enough power to charge your laptop, iPad or phone more than once before the power pack itself needs charging. You can also charge a Nintendo Switch while it's being played. Outside the RAVPower's case is made of scratch-resistant materials while inside its advanced technology protects your devices from being overcharged or short-circuiting. It also has surge protection.
The EC Technology Portable Charger is also a good pick, though it doesn't have the same brand recognition as RAVPower. The EC Technology charger increases iPhone battery life by 50 percent in just 30 minutes and is compact enough to slip into your pocket or purse.
Nicole writes for multiple Future Publishing brands covering topics from antivirus to kitchen appliances to SAS. She has over 15 years of research and writing experience, including eight years of testing and reviewing consumer products. Nicole earned bachelor’s degrees in both English and Political Science with a focus on empirical research. In her spare time, Nicole serves on several school councils and volunteers for a local arts board.
