Best USB-C hubs for iPad Pro 2025
Fast charge your iPad Pro with the best USB-C hubs.
1. Best overall
All iPads from 2018 and sooner, have converted to the universal USB-C port for charging and accessories. With this single USB-C port, you have more options when it comes to peripherals to use with your iPad Pro since there are hubs out there to add USB 3.0 ports, more USB-C with Power Delivery, SD card readers, HDMI display outputs, and more. While there are many of the best iPad Pro USB-C hubs on the market, the one we think is the overall best pick is the HyperDrive 9-in-1 USB-C Hub Adapter.
Quick List
Take a fast look through the best USB-C hubs for iPad Pro, with choices for different needs and budget. To read more about any of them, just click to jump down to our full write-ups.
Best overall
Designed specifically with the iPad Pro in mind, the HyperDrive 9-in-1 USB-C Hub Adapter offers 60W of power and features a generous nine ports. It comes in Space Gray or Silver to match the color of your iPad Pro and sits flush with the tablet when connected directly to its USB-port. While intended for the iPad Pro, HyperDrive's adapter plays nice with your MacBook and other USB-C devices.
Best for value
With its six ports and wallet-friendly price tag, the Zedela 6-in-1 USB-C Hub should be high on the list of any deal-hunters. Its included HDMI port can support up to 4K@30Hz and it has an SD card reader, though not an SD card slot. The obvious downside is that it connects to your iPad Pro via a cable which could prove to be a bit awkward.
Best for simplicity
Like the HyperDrive, this uncomplicated little adapter connects directly to your iPad Pro's USB-C port, and is ideal for connecting your tablet to a monitor for fuss-free video output. While you only get four ports, for a lot of people what's included will be enough, and like other devices on this list, the beauty of USB-C is that you can use it with other devices that support the standard, too.
Best for convenience
This space-saving adapter conveniently attaches to your iPad Pro at a 90-degree angle, keeping it out of the way while you make use of its useful assortment of ports, which include 4K HDMI output and an SD card reader, as well as a 3.5mm headphone jack.
Best on a budget
The QGeem Smart USB-C Hub is our budget pick, but you can still expect 100W power delivery and plenty of handy features, including a 4K HDMI port, a micro-SD card slot and three USB-A 3.0 ports. It's perfect for your iPad Pro and other USB-C devices and won't break the bank.
The best USB-C hubs for iPad Pro: in depth
The best USB-C hub overall
1. HyperDrive 9-in-1 USB-C Hub Adapter
Specifications
Reasons to buy
Reasons to avoid
The HyperDrive 9-in-1 USB-C Hub Adapter is a hub that connects directly to the USB-C port on the iPad Pro. It's like a small brick with a grip that helps distribute the weight evenly, preventing strain on the port itself. Unlike many other USB-C hubs, this one was designed specifically with the iPad Pro in mind.
The HyperDrive USB-C Hub Adapter includes 60W power delivery, Gigabit Ethernet, 4K HDMI, 3x USB 3.1, SD & MicroSD reader, and 3.5mm audio jack. These ports should cover all of the necessities you would need an adapter for on the iPad Pro. As far as the HDMI connection, it supports 1080p@60Hz, 2K@60Hz, and 4K@30Hz.
Since the HyperDrive is designed to be flush with the rest of the iPad Pro, the aluminum enclosure comes in either Space Gray or Silver to perfectly match your iPad Pro. Despite being designed specifically for the iPad Pro, the HyperDrive can still work with your MacBook and other USB-C devices too, so it's universally compatible.
HyperDrive also has optional grips and extension cables for this adapter to make it possible to be used with iPad Pros with screen protectors, cases, and other USB-C devices.
The HyperDrive Hub Adapter comes in aluminum made to match your iPad Pro and provides nine ports, plus pass-through charging.
The best USB-C hub for value
2. Zedela 6-in-1 USB-C Hub
Specifications
Reasons to buy
Reasons to avoid
If you're on a budget but still want a good USB-C hub adapter, then you should check out Zedela's 6-in-1 USB-C Hub.
This hub gives you a total of six additional ports: 1 RJ45 gigabit ethernet LAN port, 1 USB-C to HDMI port (4K/30Hz), 1 Type C PD charging port (87W), 13.5mm Audio/Mic jack, 3 USB 3.0 port, 1 SD card reader, and 1 TF/Micro SD card reader. Unfortunately, it connects via a cable. So, if you don't mind a dongle that is hanging off of your iPad Pro while you're working on it, then it should be fine. The price is also pretty affordable, considering what you are getting.
This hub is also compatible with any USB-C device, especially since it connects via a cable and does not sit flush with the iPad Pro. So if you don't need to use it with your iPad Pro, you can still use it with your USB-C compatible best MacBook or other devices.
The price is great, but it does hang by a cable. If you don't mind that, then you'll get all the basics, except for the SD card.
The best USB-C hub for simplicity
Satechi Type-C Mobile Pro Hub Adapter
Specifications
Reasons to buy
Reasons to avoid
If you want something simple that allows you to connect your iPad to display video on a monitor, then this Pro Hub Adapter from Satechi gets the job done and then some.
This simple little adapter connects directly to your iPad Pro's USB-C port like the HyperDrive, but it is a bit smaller and only has four ports: USB-C PD charging, 4K HDMI, USB 3.0, and 3.5mm audio jack. If you don't need to transfer photos or videos from an SD card, this hub is all you need, and the price is pretty good.
The Satechi Mobile Pro Hub Adapter is designed for the iPad Pro with USB-C. It is also made of aluminum and comes in colors that match your iPad Pro's finish, so it looks seamless. Of course, this hub will also work with other USB-C devices if need be.
Satechi's hub is simple and gives you four ports while sitting flush with the iPad Pro. However, it lacks an SD card slot.
The best USB-C hub for convenience
Baseus iPad Pro USB-C Hub and Docking Station
Specifications
Reasons to buy
Reasons to avoid
If you want something that's convenient and tucks away in the corner so it's unobtrusive, then Baseus' USB-C Hub and Docking Station are for you.
It plugs into the USB-C port, but the plug is sleek and goes out at a 90-degree angle, saving space. A short cable connects the plug to the hub, and the hub itself attaches to the corner of your iPad Pro. With this space-saving design, it stays out of the way while still providing you with all of the ports you need. You get 4K HDMI output, USB-C PD charging, SD card reader, USB 3.0 port, and a 3.5mm headphone jack.
The PD charging port provides up to 60W of power, so there won't be any reason to worry about battery life. You get fast data transfer, crystal clear picture quality, and stable connections — all in one small, compact package.
This compact hub stays out of the way in the corner while providing six useful functions.
The best USB-C hub on a budget
QGeem 100W 7-in-1 USB-C Hub
Specifications
Reasons to buy
Reasons to avoid
The QGeem Smart USB-C Hub features 100W power delivery and provides a great combination of convenience and connectivity. It features a 4K HDMI port so you can mirror or extend your laptop’s, tablet’s, or phone’s screen to stream and watch all your favorite movie and TV shows.
It has three USB-A 3.0 ports, a built-in SD/TF card slot, one USB-C Thunderbolt port, and a micro-SD card slot. It’s widely compatible with all USB-C compatible tablets and laptops. It’s an excellent budget pick and is relatively inexpensive for everything it provides.
How to choose the best USB-C hub for iPad Pro
Stay connected
We think the HyperDrive 9-in-1 USB-C Hub Adapter is the best option for those looking for the best USB-C hub designed specifically for the iPad Pro. It connects directly with iPad Pro and perfectly matches the design with the aluminum body and finish, which makes it feel as if Apple designed it.
It also gives you six more ports, including an SD card slot, which all of the other options are missing. And if you need it for another USB-C device, the HyperDrive still works.
Looking for a new iPad? Check out the best iPad sales and deals.
