Best HomeKit cameras 2024
If you're looking for an easy way to look over your property and secure a little peace of mind, the best HomeKit cameras are a great investment. Being able to use them both indoor and out, and connect to your iPhone or iPad when you're away, you can check up on your house and make sure nothing goes wrong as you pop off for a trip or for your holidays.
The reason you may want to commit to something that specifically works with Apple HomeKit is you can create your own automation, with lights turning on at certain times to get a better view.
We've managed to test out and review tons of HomeKit cameras, and we have whittled it down to just a few of our favorites.
Here are the best HomeKit cameras right now.
A picture of Tammy Rogers
Tammy Rogers
HomeKit fanatic
As the resident HomeKit obsessive, I've got in a prime place to recommend what HomeKit gadgets you should slip into your home. In this case, I've trawled our extensive review library to see what HomeKit cameras I'd recommend you add to your setup so that you can keep your home safe.
1. Quick List
Back to the top ^
Best Overall
Logitech circle view camera on a wooden shelf
(Image credit: Logitech)
Best Overall
Specifications
Wireless protocol: 2.4GHz
FOV: 180 degrees
Night Vision: Yes
Speaker: Mono
Video resolution: 1080p
Reasons to buy
Weather resistant
Great image quality
No app or account needed
Reasons to avoid
Expensive
Lacks motion zones and advanced settings
Slightly odd design choices
The Logitech Circle View is a super solid little camera with a host of great features. You can hook it up outside, inside, or wherever you might need to monitor, and it's support for HomeKit secure video means that it you'll be able to store all your video within the Apple Home app, crucially without an extra 3rd party app from Logitech.
It's small and compact, blending in around any house or into any interior decoration. In our review, we loved the weather resistance and the incredible image quality, as well as the responsiveness of the camera.
It's not cheap, however – but if you want top quality, then as always you're going to have to pay a little to get it. It would be nice as well to have motion zones and some more advanced settings on board, but as it stands this is a very solid security contender for your HomeKit setup.
Best for outdoors
Eve Outdoor cam
(Image credit: Eve)
2. Eve Outdoor cam
Best for outdoors
Specifications
FOV: 157 degrees
Night Vision: Yes
Speaker: Mono
Reasons to buy
Weatherproof case
10-day recording history
HomeKit compatible
Reasons to avoid
Needs existing light fixture
If you want a camera that you can stick outside, then the EVE outdoor cam is an excellent option. It's not cheap, but its very sturdy, and it's built in light is great for illuminating porches or gardens so that you can see what's going on. There's also night vision on board as well, so that you don't need to switch the light on in the dark – great if you want to see what kind of wildlife finds its way into your garden.
This isn't one that we've reviewed, but reviews around the web love it's features – they're not a fan however of how the camera fits. It needs to be placed on existing light fixtures, making placement a little harder than it perhaps should be. If your lights outside are fitted correctly, however, you'll be golden.
Best for indoors
eufy Security Solo IndoorCam P24
(Image credit: Christopher Close)
Best for outdoors
Specifications
FOV: 360 degrees pan & tilt
Night Vision: Yes
Speaker: Mono
Video resolution: 2K
Reasons to buy
Affordable price
Pan and tilt controls
Image and night vision quality
Reasons to avoid
2.4ghz Wi-Fi only
Upright wall mount not included
HomeKit not available at launch
Perfect for use indoors, the eufy Indoor Cam Pan 2K is a great little security camera that you can place around the house. It's super affordable, and its pan and tilt controls make controlling the camera an absolute doddle. The image quality is also top-notch, and we particularly like the fun, almost cartoon-esque look of the little camera.
There are a couple of things we're less fans of. It would be great if the camera could be mounted on a wall, sideways, but you can only mount it in an upright position. There's only one version of WiFi on board as well, the now relatively out-of-date 2.4Ghz version. On launch, HomeKit wasn't available, but subsequent updates have made the standard available.
Best as a hub
aqara 2k security indoor camera hub g3
(Image credit: Aqara)
4. aqara 2k security indoor camera hub g3
Best as a hub
Specifications
Wireless protocol: 2.4/5GHz
FOV: 360 degrees pan & tilt, 110 degree lens
Night Vision: Yes
Speaker: Mono
Reasons to buy
It's got removable cat ears
Built-in hub
Well priced
Reasons to avoid
Won't work outdoors
Not all visible depending on the smart home platform you use
There aren't many HomeKit gadgets out there that want to make you smile, but the Aqara indoor camera hub G3 certainly puts in a lot of the heavy lifting for the space. That silicon cat ear hood can be pulled off if you're a misery and hate fun – but there are also some other great reasons that you might want to pick up this super cute little camera hub.
For one, it's a hub that will link all your other Aqara sensors and devices to HomeKit, making them all work properly with the standard. It's also a really good camera, with brilliant resolution and a great wide-angle view. It's also very well priced – we're yet to review the camera, but those that have love the camera's features, with little bad to say about the little cat-eared camera that could.
Best doorbell
Logitech Circle Video Doorbell installed near a door
Best doorbell
Specifications
FOV: 160 degrees
Night Vision: Yes
Speaker: Mono
Video resolution: 1200x1600
Reasons to buy
Easy installation
Excellent image quality
Fast response times and notifications
Reasons to avoid
Expensive
Requires existing wiring
Recording requires an iCloud storage subscription
The Logitech Circle View Doorbell is another excellent entry into Logitech's product lineup, and this one straps to your doorframe, ensmartening your front door. There are some great features in the doorbell, such as the already excellent Logitech cameras that power it, as well as support for HDR and a 160-degree field of view.
There's night vision on board too, so that you can see who might be coming to your door in the middle of the night. There are a couple of things to be aware of aswell, however; it needs to be hooked up to your existing doorbell wiring, so no battery power. You'll also need to pay a decent sum to get a hold of one – it's not a cheap device.
Best wireless
eufyCam 2C
Best wireless
Specifications
FOV: 135 degrees
Night Vision: Yes
Speaker: Mono
Reasons to buy
Excellent night vision
Integrated floodlight
6-month battery life
Reasons to avoid
Missing anti-theft detection
Sometimes slow to load in the Home app
Non-removable batteries
This set of Cameras is a great option if you're looking for something with no wires. There's a central hub that two battery operated cameras hook up to, and you can add more cameras when the need arises. Those cameras only need recharging when their batteries go out, letting you circulate which cameras aren't in operation while the other one charges.
We love the size and look of the little cameras in our review, and as a package getting a couple of cameras is really good for security coverage. The cameras can be put inside and outside as well, so there's plenty of range to them. There are just a couple of things to note about them; the batteries are built in, so you can't change them, and there isn't any anti-theft detection. If someone wanted to run off with them, you'd be stuck camera-less, only realising when you go to check the feed.
Best value
eufy Security Solo IndoorCam C24
Best value
Specifications
FOV: 125 degrees
Night Vision: Yes
Speaker: Mono
Reasons to buy
Affordable price
2K image quality
2-way audio
Reasons to avoid
eufy app lacks 2FA
microSD card not included
2.4ghz Wi-Fi only
The tiny little eufy Indoor Cam 2K is a very accomplished camera, with great resolution and 2-way audio so that you can speak over the camera, and hear what is said back to you. It is for indoor use – you're not going to want to stick this thing outside lest it fill with water when it rains, but it's small enough to blend in with any room in the house.
There are position adjustments in the camera's sturdy stand, and you can mount it to a wall if you need. There's a microSD card slot on the side as well, although you'll need to supply your own – there isn't one in the box. There's only support for WiFi 2.7GHz too, so it can be a little slow to react when you open it in app.
Easiest setup
Eufy Cam
Easiest setup
Specifications
FOV: 150 degrees
Night Vision: Yes
Speaker: Mono
Reasons to buy
1080p HD visuals
Easy set up process
Magnetic stand
Reasons to avoid
Expensive
Indoor use only
Night vision not the greatest
The Eve Cam was Eve's first go at a smart home security camera, and an excellent first shot it was too. It's super compact, and the stand means that the camera can swivel around so that you can place it wherever you need. It is indoor only, but it's emphasis on privacy makes for a camera that gives you more piece of mind that it's around your house.
Built from the ground up for HomeKit, the Eve cam works seamlessly with the Apple Home app, and lets you store video over HomeKit secure video. It will also work with all your sensors and other HomeKit devices so that you can make more automations and commands.
It's not cheap, and the night vision could be better, but beyond that, it's an excellent home security camera.
Best high-end
ecobee SmartCamera
Best high-end
Specifications
FOV: 180 degrees
Night Vision: Yes
Speaker: Mono
Reasons to buy
Digital pan controls
Person detection and focus mode
Reasons to avoid
Expensive
Video recording requires subscription
Notifications do not include images
If you want the best camera possible, then the ecobee SmartCamera is the one to go for. It's a pretty device that will cost you a lot, but comes packed full of features that make it one of the best cameras that money can buy. You can adjust the view with the app, so you can just place the camera down in roughly the right place, and then fine-tune with the app. The person detection is excellent, and the image quality is very good as well – just be aware of a couple of caveats before you go in.
For one, you'll need a new subscription to ecobee's service before you can record any video, which is another thing to pay for on top of the expensive device price. in addition to that, the notifications are text only, so there's no at a glance images so that you can just have a quick look at what's happening. Beyond those two issues, however, the ecobee SmartCamera is an excellent camera if you're looking for the best of the best.
Q&A
How do I choose the best camera for me?
The best HomeKit cameras for the Home app keep an eye on all the happenings in and around your home. HomeKit cameras provide instant notifications from the Home app, including a preview image of who is lurking around right on your home screen. HomeKit automation also allows the motion sensors built into some cameras to trigger HomeKit door locks when something passes by, which provides an extra layer of security.
Thanks to compatibility with the Apple Home app and standardized HomeKit Secure Video features found in all of our picks for the best HomeKit cameras, choosing one for your home is easier than you may think. Aside from price, all you need to decide is whether you want an indoor or outdoor camera and how you will provide power to your pick. While some cameras may include extras like smart hub capabilities and built-in lighting, if you just want the basics, any of these cameras will give your home a hassle-free security upgrade.
If you're looking for the most flexible HomeKit camera, look no further than the Logitech Circle View. This versatile smart camera supports all of the latest HomeKit Secure Video features and can withstand outdoor elements. We also love that this camera doesn't require a separate app or account. Instead, it's managed entirely through the Home app built-into the iPhone, iPad, and Mac.
If you need an all-wireless option built for the outdoors, then the eufyCam 2C gets our recommendation. This camera has a built-in rechargeable battery that can last up to six months on a single charge, supports HomeKit Secure Video, and has an integrated spotlight that enables color night vision.
Tammy Rogers
Senior Staff Writer
With contributions from
