Chargeasap's new Flash Pro Plus is a monster battery pack for Apple gear
- Chargeasap has announced a new charger that promises to charge all the things.
- The battery pack even has an OLED screen to keep you informed of what's going on inside.
Fancy getting your hands on a battery pack that can charge six devices at once? What about one that supports MagSafe and Apple Watch charging? Sounds good, right? And if I then told you it has an OLED display for showing battery information, you'd be interested wouldn't you? Right now you can get all of this and more via the Chargeasap Pro Plus.
Available via Indiegogo, the whole thing costs $149 which is a lot less than the $319 that it will cost when it goes to retail. That's quite the saving. And it's quite the battery pack as well.
Flash Pro Plus has not just 2 but 3 USB-C Power Delivery 3.0 ports as well as 1 x USB-A port, so that's four different USB devices that can be charged at the same time. Then use the magnetic wireless charger for a fifth and put your Apple Watch on top for a sixth. Six devices, all charging at once, from a battery pack. That's insane. To top it off, Chargeasap says the magnetic charger supports 15W charging, too. You could be charging your iPhone 12 and Apple Watch Series 6 at the same time!
Some Android phones are supported as well — in case you have a friend that needs a charge!
Flash Pro Plus can deliver a powerful 100W Power Delivery 3.0 from a single USB-C port while many of the competition struggle to even reach 60W. Additional USB-C ports are able to reach 60W and 20W respectively. We've also thrown in a powerful 50W USB-A that's been specially designed to be compatible with Oppo (50W), OnePlus (50W),Vivo (50W) and Huawei (22.5W) proprietary fast charge technology as well as supporting Qualcomm Quick Charge 3.0. To top this all off Flash Pro Plus features a fast 15W magnetic wireless charging pad compatible with Magsafe devices and a separate wireless pad to support 5W Apple Watch.
Oh, and let's not forget the OLED screen. That 1.3-inch OLED display provides "real time information about not only just the battery percentage remaining, but the power output from each port measured in Watts and Amps when charging a device as well as the running temperature."
All sounds good, right? You can order yours now with deliveries expected by the end of the year. If you need a big battery pack that can offer 25000mAh/92.5Wh of capacity, this is the place to look.
Looking for something a little less beefy? Check out our list of the best battery packs of the year so far.
Oliver Haslam has written about Apple and the wider technology business for more than a decade with bylines on How-To Geek, PC Mag, iDownloadBlog, and many more. He has also been published in print for Macworld, including cover stories. At iMore, Oliver is involved in daily news coverage and, not being short of opinions, has been known to 'explain' those thoughts in more detail, too. Having grown up using PCs and spending far too much money on graphics card and flashy RAM, Oliver switched to the Mac with a G5 iMac and hasn't looked back. Since then he's seen the growth of the smartphone world, backed by iPhone, and new product categories come and go. Current expertise includes iOS, macOS, streaming services, and pretty much anything that has a battery or plugs into a wall. Oliver also covers mobile gaming for iMore, with Apple Arcade a particular focus. He's been gaming since the Atari 2600 days and still struggles to comprehend the fact he can play console quality titles on his pocket computer.
