Power up your devices with RAVPower's USB-C fast chargers down as low as $12
Powering up your devices could be much quicker if you began using a faster charger. If you have any Power Delivery-compatible devices, then any time you spend waiting for them to charge on a low-power charger is wasted.
Fortunately, it's not super expensive to snag something better and, right now, RAVPower is offering USB-C PD chargers from as little as $11.99 with the below deals.
The most affordable pick is RAVPower's 30W Pioneer charger which offers a USB-A port and a USB-C connector. With support for 18W Power Delivery 3.0 over that USB-C port, you'll be able to charge up your compatible phone quickly while also having a USB-A port for charging a second device.
It's got a compact design and a foldable plug for easy transportation, too. At $11.99 with code 2RYS8JWW, this is the lowest we've seen it go so it's definitely worth upgrading to.
Those wanting a little extra oomph could move up to the 65W Pioneer charger. It's also equipped with a USB-A port and a USB-C port, though its output is higher which makes it a wiser choice if you think you might want to use it to power up larger devices like tablets and even laptops.
Its USB-C port can provide up to 60W of power which is enough to recharge a MacBook Pro in just a couple of hours and it also works with phones, Nintendo Switch, and more. This charger also utilizes GaN technology that enables these faster speeds without producing as much heat, allowing for a compact design.
It falls to just $21.44 at Amazon when you clip the coupon on its product page and then enter code UBB5HEDJ during checkout with the two discounts stacking together for almost $16 off.
If all of your devices use USB-C, you can eschew the USB-A port in favor of a second USB-C connector with the 90W RAVPower Pioneer GaN charger. This is the most power of the three on offer today and can even be used to power two laptops at once. Clip the $10 coupon on its product page to grab it at its best price in months.
The charger is smart enough to adjust its output according to what is plugged in. Use just one of its ports with a laptop and it will provide full power for a faster charge or connect up a couple of devices simultaneously to split its 90W total output.
This compact charger is pretty slim considering its power and even features a foldable plug, along with built-in safeguards to protect against overcharging, short-circuiting, and overheating. It also comes with a 1.5m USB-C cable.
