Source: StackCommerce
If you use GPS or stream songs while you drive, you may find your phone is dead by the time you park. The Wireless Fast Charging Vehicle Phone Mount provides a neat solution, and it's currently 71% off MSRP at just $19.99.
This useful accessory fixes two problems at the same time, holding your phone securely while topping up the battery.
Compatible with any smartphone between 4 and 6.5 inches wide, the mount latches on to any air vent inside your car.
The design allows you to rotate your phone through 360 degrees, with a simple locking mechanism for quick docking. It can even handle your phone with the case still attached.
Once your phone is docked, the mount becomes a 10W wireless charger. A built-in chip automatically detects each device, with support for Android and iOS.
This charger also had overcharge and short-circuit protection, while power comes from any USB source. This means you can use a car socket adapter or a battery pack.
Order today for $19.99 to get the charging mount, which is normally $69.
Prices subject to change
As well as our amazing group of regular contributors, the iMore staff team currently consists of: Gerald Lynch — Editor-in-Chief Stephen Warwick — News Editor Daryl Baxter — Features Editor John-Anthony Disotto — How To Editor Tammy Rogers — Senior Staff Writer James Bentley — Staff Writer
