Harry Potter: Wizards Unite: What are Portkeys and how do they work?
In the world of Harry Potter, Portkeys are innocuous objects that, when touched, transport you to a different location in the world. In Harry Potter: Wizards Unite, Portkeys are found inside of Portmanteaus that appear on the map. By walking, you can unlock them, and then transport yourself to a new location where you can find new Foundables for your registry.
What are Portkeys, and how do they work?
As you wander across the world, you'll find a variety of different Portmanteaus. They are the triangle topped items that appear on the map in the same way you find Ingredients or Traces. There are four different varieties of Portmanteaus that you will find, Prized, Precious, Paramount, and Brilliant Portmanteau Portkeys. Much like eggs in Pokemon Go, they are items that require different distances to unlock with keys before you can see the actual Portkey.
Your inventory can hold up to ten Portmanteaus at a time, but there is no way to tell what size Portmanteau appears on the map until you tap it to add it to your inventory. The only Portmanteau that does look different on the map is the Brilliant Portmanteau, which is only available during Brilliant Events. When a Portkey is ready to be opened, you'll get a notification from the app, but you don't need to open it right away. Instead, use Barrufio's Brain Elixir potion to give you an XP boost and then open up several in quick succession to get the most XP.
When a Portkey is ready to be opened, the Portmanteau will drop away to reveal one of three items. For 2 KM Portkeys, that item is an old Boot; for 5 KM Portkeys, you'll get a Kettle; and 10 KM Portkeys will reveal a Deflated Football.
How do you get gold and silver keys?
To unlock a Portmanteau and access the Portkey inside, you'll need a key. When you start the game, you automatically receive a Golden Key. This Key can be reused on multiple Portmanteaus, and will never break or disappear. As you level up in the game, you will also receive Silver Keys. These are only good for one Portmanteau and will disappear when you unlock the Portkey. In addition to receiving Silver Keys as a reward, you can also purchase more Silver Keys from Diagon Alley.
Your best bet is to use your Gold Key on 2 KM Portmanteaus and use Silver Keys on 5 KM and 10 KM Portmanteaus. This way, you can keep reusing your Gold Key as frequently as possible so that you can open more Portkeys in a timely manner.
How do you open a Portkey?
- To open a Portkey first, you need to find a Portmanteau on the map. They look like little boxes with triangular tops.
- Use a key on the Portmanteau, and then walk the requisite distance. The app will send you a notification when you've walked far enough.
- Tap Go to Portkeys.
- Tap the Portkey that is ready for use.
- Tap Use Now.
- The menu will close, and AR mode on your phone will open, showing you a boot in front of you somewhere.
- Tap on it, and a portal will open and transport you from wherever you happen to be, to whatever location the Portkey is connected to. Some locations include Ollivander's Wand Shop in Diagon Alley, Borgin and Burke's in Knockturn Alley, Dolores Umbridge's Office, and Hagrid's Hut on the Hogwarts grounds.
Once you have been transported to the new location, you'll need to find five Wrackspurts hiding there. They appear as small glowing orbs, and tapping on them lets you find them. Each Wrackspurt will give you something to find it, and it seems to be pretty random. You could receive ingredients, items, XP, or even Spell Energy, and you'll see them stacked at the top of the screen. Once you find all five, you'll be brought to a screen that shows you the rewards that you have unlocked. Along with the items or XP you receive from the Wrackspurts, you'll also get a Foundable fragment for your registry.
Adventure Sync
Beginning in February 2020, Niantic will be introducing Adventure Sync to Harry Potter Wizards Unite. Adventure Sync is a popular feature used in Pokémon Go that works in the background to track a player's distance traveled while the game is not running. In Pokémon Go, this means that players can hatch Eggs and collect Buddy Candy, without keeping the app open and running all the time. For Harry Potter Wizards Unite, this distance will be applied to unlocking Portkey Portmanteaus. Players using iPhones will be able to sync Harry Potter Wizards Unite with Apple Health, while players using Android devices will be able to sync with Google Fit.
While both are optional and can be turned on or off at any time, if you're already using Apple Health or Google Fit, you're going to want to use this feature to unlock your Portmanteaus even when you don't have the game running.
Want to learn more about Harry Potter: Wizards Unite?
Portkeys are just one part of what Harry Potter: Wizards Unite has to offer. We've compiled a great guide for Beginner's Guide for anyone looking to explore more of what the game has to offer!
Jen Karner is a VR Specialist with a taste for all of the weird things. She's usually found playing the latest time-waster on her phone or tablet, when she's not wrecking aliens on her PlayStation VR.
