How to replace an AirTag battery
While it was rumored for a long time, Apple finally launched the AirTag in 2021. This is Apple's own foray into the item tracker market, and it's a direct competitor for brands like Tile, Chipolo, and more. But what makes AirTag stand out from the crowd are features like Precision Finding, which uses Apple's U1 Ultra Wideband chip inside, and how it utilizes the entire Find My network to help you track your lost items.
While Apple is notorious for making it hard to replace batteries on most of its products, it's actually very easy to replace an AirTag battery, just like most of the other best Bluetooth item trackers on the market. That's because it just uses a standard CR2032 battery, which you can find at pretty much any store. A single 3-Volt lithium coin cell battery will power your AirTag for around one full year with regular use, at which you'll need to replace it.
Here's how to replace an AirTag battery, no trip to the Apple Store required.
Before you replace your AirTag battery, if it is in one of the best AirTags accessories like a case or loop, make sure to remove it so that the AirTag is by itself.
- Flip your AirTag so that the white side faces down and the stainless steel side is up.
- With two fingers, simply push in and twist counter-clockwise on the metal — similar to opening a child-proof cap on a medication bottle.
- Remove the old CR2032 battery.
- Replace it with a fresh CR2032 battery with the "+" facing up.
- Place the stainless steel cover back on by twisting it clockwise back until it locks.
As you can see, replacing an AirTag battery is super easy, barely an inconvenience.
How can you tell when you need to replace the battery?
According to Apple, one CR2032 should give you about a year of AirTag usage with normal use. Of course, this may vary depending on how much you want to play with the AirTag features like Precision Finding with one of the best iPhones, like the iPhone 13 Pro. Keep in mind that you need at least an iPhone 11 for Precision Finding to work.
Thankfully, you don't even need to worry about that. Through the Find My app in iOS 15, you'll be able to get a notification when your AirTag battery is running low, so you can purchase a CR2032 battery and change it out with time to spare. The Find My app will even tell you the current battery level of each AirTag as well, so you'll always know how much battery is left at all times.
Track everything you need
AirTag is one of our favorite Bluetooth item trackers. With AirTag, we never need to worry about losing our keys or bags again, and if we misplace them, we can easily find them with Precision Finding. And if your AirTag is out of juice, just pop that cover off and replace the battery, easy!
Updated April 2022: These are still the same steps to replace an AirTag battery.
