How to switch between Wi-Fi and Bluetooth mode on the Sonos Move
Learn how to use your Sonos Move both on your network and off.
The Sonos Move is the first Sonos speaker that you can use outside of the Wi-Fi network that it's paired with. You might be wondering how that's possible. It works because this Sonos speaker features Bluetooth. The Sonos Move is the first Sonos speaker to feature two different modes. Use it on Wi-Fi like any other Sonos speaker or you turn on Bluetooth instead. In this guide, we'll explain how to switch between Wi-Fi and Bluetooth mode on the Sonos Move.
How to Switch Between Wi-Fi and Bluetooth Mode
Before pairing your Sonos Move in Bluetooth mode for the first time, it must be set up in Wi-Fi mode. If you are setting it up for the first time with Bluetooth mode, follow these steps.
- Press and hold the mode button on the back of the Sonos Move, between the power and the join button.
- Move will chime and the LED will turn blue.
- On the device you want to pair, go to Bluetooth and search for Move.
- Select it, and the blue LED will be solid. You will hear a chime when pairing is complete.
- The next time you press the mode button, your device will automatically connect.
If you want to switch back to Wi-Fi, provided you are on your network, simply press the mode button. It will connect you right back to your network.
Easy Listening
Like other Sonos speakers, the Move is great to use and sounds fantastic on your Wi-Fi network. You can access your music and content from various different services, including Apple Music. However, using it on the go is what makes it unique and if you follow the steps to switch from Wi-Fi to Bluetooth you will enjoy your speaker on the go.
Once you master the steps above it will be easy to take your speaker with you to the pool, the beach or a party. With 11 hour battery life you will be able to enjoy your tunes all day while out of the house.
Sonos Move is a unique member of the Sonos family that can be used on both Wi-Fi and Bluetooth. You can choose between black and white to suit your needs. Take it to the pool, the backyard, a party or the beach. It can run for up to 11 hours on battery so no worries about finding an outlet while you are on the go.
**Mark Goldschmitt** is the father of three boys and loves anything Apple. Born and raised in Queens, NY, and currently residing on Long Island, Mark is a lifelong New York Mets fan. {.end}
