Join the discussion: Power Bank Advice-MFI Certified necessary?
So you have your iPhone and your iPad and you're ready to go on your road trip/vacation/cross-country unicycle experience when it hits you: a power bank might actually be a good call!
As you do a bit of research, you realize that there are some models that are MFI-certified, and others that don't have the same label. Some have great ratings, while others warn buyers of dangers of getting non MFI-certified gadgets… So what's the truth?
Looking to get a power bank for a trip and we will use it to charge two iPhone 7+'s and an iPad Air 2. I am looking for a descent answer as to what I need to protec Looking to get a power bank for a trip and we will use it to charge two iPhone 7+'s and an iPad Air 2. I am looking for a descent answer as to what I need to protect our Apple devices. I have read that some power banks are MFI...
MidnightinGotham
Some people say that it's okay to skimp on MFI-certified things if they're not something as intense as a power bank…
For something like a power bank, I would say getting one from an established, well known vendor that stands behind their product is more important than the MFi certification. Personally, I'm a fan of Anker and Jackery. I've had a few of their battery banks in the past and they've been solid. Other tech sites seem to like Aukey although I've personally never owned any of their products.
njlx2016
While others claim that they've picked up random power banks and gear from a convenience store over the last couple of years without any problems:
I just buy them from the convenience store. I have had multiple power banks over the years and never had any issues with my devices nor the power banks.
Tartarus
So to MFI-certify, or to no MFI-certify, that is the question!
Hop into the iMore forums and join our discussion to let your voice be heard! Do you think a MFI-certification on a power bank is necessary and needed, or do you think you can skip the formalities and pick up a power bank regardless?
Join the discussion on the iMore forum!
