Leave Low Power Mode behind with EasyAcc's USB-C to Lightning cable down to just $5
Easyacc Usb C Lightning Lifestyle
Amazon has the EasyAcc 6-Foot USB-C to Lightning Cable on sale for only $4.99 when you apply code YSWUJ2RS during checkout. That gets you a 50% off the current $10 price tag, and so far the reviews are positive as well. It sold for as much as $15 earlier this year.
This cable is long enough to reach wherever you may need, and it'll charge your phone up quickly too. It's braided nylon for added durability and MFi-certified so it works perfectly. Use the below code to save.
EasyAcc Gooseneck Tablet Holder
$12.99 $25.99 Save $13
Available in white, this stand is made of magnalium alloy for a durable yet flexible arm that can twist into various viewing positions. It's suitable for devices from 4-10.6 inches wide and is half off with the below code.
EasyAcc Battery Charger Case Works for iPhone X XS, Wireless Charge Case Cover 5000mAh Battery Qi Rechargeable Shell
$16.99 $19.99 Save $3
$17.99 $19.99 Save $2
$18.99 $19.99 Save $1
$19.99 $18.99 Save $-1
Apple only recently opened up the certification process for USB-C to Lightning cables, and accessory makers are already getting their own versions onto the market — and for much less than Apple's cables cost. Using this cable in conjunction with a compatible USB-C adapter, you'll be able to charge up your devices super quickly.
Apple doesn't make it super clear, but fast charging has been present in the iPhone since the iPhone 8 and iPhone X were released, but it can only be done using a USB-C to Lightning cable. Previously, Apple was previously the only provider of those and they didn't come free with your phone (though the iPhone 11 Pro does now included USB-C peripherals). Using EasyAcc's cable with a USB-C adapter will allow you to charge your iPhone from 0% to 50% in 30 mins. Fast charging also works on Apple's newest iPad models.
This 6-foot cable works for high-speed data transfers and it's extra-durable thanks to the nylon braiding. If you've upgraded to a Mac laptop that only has USB-C ports for connectivity, this cable is an essential buy if you want to manually sync content or just charge up your phone via your Mac. Your purchase includes an 18-month warranty too.
