Meross releases versatile HomeKit-enabled MSL610HK Smart LED Floor Lamp
- Meross has announced the launch of a new HomeKit-enabled floor lamp.
- The Meross Smart LED Floor Lamp supports color temperature adjustments, dimming, and more.
- New lamp is available now through Amazon for $79.99.
Meross has announced the release of another new HomeKit accessory on Thursday — the Meross Smart LED Floor Lamp. The latest HomeKit lamp from Meross sports a modular three-piece design that allows it to work on the floor or a table with the included base or clamp mount.
The smart floor lamp supports Apple HomeKit, Amazon Alexa, Google Assistant and SmartThings. Remotely control the modern floor lamp from anywhere with internet access by the APP. Easily control the corner floor lamp with simple voice commands. Note that HomeKit remote control requires an Apple TV or an iPad in your home.
The Meross Smart LED Floor Lamp features a slim black frame that measures 54.7-inches tall as a floor lamp and 22-inches as a table lamp. Near the top of the lamp is a flexible gooseneck light that allows for 360-degree rotation and tilt adjustments, and at the bottom is a weighted base that holds it all in place.
While it doesn't support color, the Meross lamp is tunable and supports color temperature adjustments ranging from 2700 to 6000K. The 12w lamp has a peak brightness of 650 lumens and is fully dimmable from 1-100% using the included remote or via smart app connectivity.
In addition to HomeKit and the Home app, the Meross Smart LED Floor Lamp is compatible with Amazon's Alexa, Google Assistant, and the Meross app when connected to a 2.4ghz Wi-Fi network. Smart features include staples such as schedules, timers, and automation with other accessories — all without the need for a dedicated hub.
The Meross Smart LED Floor Lamp is available online through Amazon for a retail price of $79.99. However, as with most Meross product releases, the company is celebrating the launch by offering a $25 discount that you can score by clipping a coupon on the Amazon product page.
Three-in-one
The versatile Meross Smart LED Floor Lamp adds smart lighting to almost any room in the home with a modular design that allows for on-the-floor — or tabletop, usage.
