Monster Hunter Rise Charge Blade: Best builds, tips and tricks
Considering that there are 14 weapon types to choose from in Monster Hunter Rise, it's not surprising that some can find the game a bit overwhelming. However, the wide range of options also means the game can work with several different play styles, as long as you know how to use your chosen weapon. In this guide, we'll dive into the Charge Blade, its fighting style, attacks, and the best builds to use with it.
Monster Hunter Rise is a relatively large game on Nintendo Switch. Make sure to have adequate space on your microSD card, so you can play without a hitch. Without further ado, let's dive into the Charge Blade.
Monster Hunter Rise Charge Blade fighting style
Much like the Switch Axe, the Charge Blade is a complicated weapon that has both a Sword form and an Axe form. The Sword moves about quickly and is great for blocking while the Axe can be charged up to deliver devistating attacks. You'll need to store up energy while in the Sword mode and then release it by switching to Axe mode.
Monster Hunter Rise Charge Blade controls
Controls | Function | Header Cell - Column 2 |
Sword Mode: | Row 0 - Cell 1 | Row 0 - Cell 2 |
X | Sword: Weak Slash | Row 1 - Cell 2 |
X + A | Sword: Forward Slash | Row 2 - Cell 2 |
L Joystick + A (during combo) | Sword: Fade Slash | Row 3 - Cell 2 |
ZR + X | Sword: Morph Slash | Row 4 - Cell 2 |
ZR + A | Charge | Row 5 - Cell 2 |
ZR | Morph/Reload | Row 6 - Cell 2 |
Axe Mode: | Row 7 - Cell 1 | Row 7 - Cell 2 |
X | Axe: Rising Slash | Row 8 - Cell 2 |
Rapidly press A | Axe: Wild Swing | Row 9 - Cell 2 |
A | Axe: Element Discharge | Row 10 - Cell 2 |
X + A | Axe: Amped Element Discharge | Row 11 - Cell 2 |
ZR | Morph/Reload | Row 12 - Cell 2 |
- Charge Gauge: Attack in Sword Mode to build up Sword Energy. Build up too much energy and attacks will bounce off. Perform Charge Phials while the gauge is yellow or above to fill a phial, which can be used in Axe Mode to perform powerful attacks.
- Attacks that Block: Some sword mode attacks have blocking frames, like the end of Spinning Slash or the start of Morph Slash. If an attack hits while your shield is facing forward, you'll block automatically.
- Charged Attack: Condensed Element Slash and Charged Double Slash will not execute properly if you hold the button for too long. Release the button at the right time to use these moves successfully.
- Sword Boost Mode: Perform a Sword: Condensed Element Slash during an Elemental Boost to enter Sword Boost Mode. In this mode, your sword will not be deflected and you will gain additional attacks.
- Element Discharge: While in Axe Mode, you can use phials to perform powerful attacks.
- Element Boost: With at least 1 phial applied, perform an Axe: Elemental Roundslash, and your shield will be elementally boosted, improving power and guard capacity in Axe Mode. Axe: Amped Element Discharge becomes Axe: Super Element Discharge. Successfully blocking an attack in this state triggers a shield explosion.
- Activate Phial Effects: A charge blade uses Impact Phials and Elemental Phials; its Element Discharge releases each phial's effects
- Impact Phial — stuns the target.
- Element Phial — Deals explosive damage of the same elemental type as the weapo to the target.
Monster Hunter Rise Charge Blade combos
Combos | Function | Header Cell - Column 2 |
Sword Mode | Row 0 - Cell 1 | Row 0 - Cell 2 |
X + A, X, X | Sword: Basic Combo: Sword: Forward Slash > Sword: Return Stroke > Sword: Spinning Slash | Row 1 - Cell 2 |
Hold A, X + A, X + A, ZR | Elemental Roundslash Combo: Sword: Charged Double Slash > Sword: Shield Thrust > Axe: Amped Element Discharge > Axe: Element Boost Spinning Slash (Power mode requires more than 1 phial) | Row 2 - Cell 2 |
Hold A, ZR + A, Hold X | Sword: Sword Mode-boosting Combo: Sword: Charged Double Slash > While Charging > Sword: Condensed Element Slash | Row 3 - Cell 2 |
Axe Mode | Row 4 - Cell 1 | Row 4 - Cell 2 |
L Joystick + X, A, A | Axe:Combo into Amped Element Discharge: Axe: Dash Slam > Axe: Element Discharge II > Axe: Amped Element Discharge | Row 5 - Cell 2 |
X, A, X, A | Axe: Combos from Axe Mode into Element Discharge: Axe: Rising Slash > Axe: Element Discharge II > Axe: Rising Slash > Axe: Element Discharge II | Row 6 - Cell 2 |
Monster Hunter Rise Charge Blade Silkbind Attacks
Silkbind Attacks | Function | Header Cell - Column 2 |
ZL + X | Morphing Advance: Wirebug launches you forward and your blade switches to Axe mode. You cannot be stunned or knocked while in motion. | Row 0 - Cell 2 |
ZL + A | Counter Peak Performance: This move readies your shield and ties you to the ground. If you're hit while in this state, your phials completely fill up. | Row 1 - Cell 2 |
ZL + A | Axe Hopper: Bring the axe crashing down overhead to launch you into the sky with Ironsilk. While going up, you can perform an Elemental Discharge. | Row 2 - Cell 2 |
Monster Hunter Rise Charge Blade Switch Skills
Each weapon in Monster Hunter Rise has unique Switch Skills, so called because you can have one of two skills activated for each attack at a time.
Attack | Switch Skills |
Silkbind Attack | ○ Counter Peak Performance: If you successfully block an attack your phials are filled and you can perform other attacks. (Wirebug Gauge recovers at a medium rate).○ Axe Hopper: Shoots you into the air by slamming your axe down. While going up, you can perform an Elemental Discharge. (Wirebug Gauge recovers at a medium rate). |
Regular Attack | ○ Condensed Element Slash: Element Regeneration gets activated when charging. This also switches the weapon into Axe Mode. Longer hits performed in Axe Mode turn into Phials.○ Condensed Spinning Slash: Element Regeneration gets activated when charging. This also switches the weapon into Axe Mode so you can hit several times before disengaging it. Longer hits performed in Axe Mode turn into Phials. |
Monster Hunter Rise Charge Blade Best Builds
As always, the best builds are a matter of opinion. I prefer to wear gear that offers plenty of defense. Here are the builds that will help compliment the Charge Blade's abilities.
Best Builds for 2 Star Quests
Area | Best equipment |
Weapon | Regas Hyper II |
Head | Izuchi Helm |
Chest | Hunter's Mail |
Arms | Alloy Vambraces |
Waist | Chainmail Belt |
Legs | Baggi Greaves |
Stats & Skills for this build:
- Defense: 38
- Fire: -3
- Water: -2
- Thunder: -3
- Ice: 1
- Dragon: 1
- Attack Boost Lvl 2
- Critical Eye Lvl 2
- Guard Lvl 1
Best Builds for 4 Star Quests
Weapon | Hyperguard |
Head | Barroth Helm |
Chest | Rhenoplos Mail |
Arms | Rhenoplos Braces |
Waist | Barroth Coil |
Legs | Basarios Greaves |
- Defense: 92
- Fire: -2
- Water: -4
- Thunder: 7
- Ice: -5
- Dragon:-3
- Affinity Lvl 2
- Attack Boost Lvl 1
- Guard Lvl 1
- Load Shells Lvl 1
- Defense Boost Lvl 2
- Stun Resistance Lvl 1
Best Builds for Endgame
Weapon | Sinister Shade Axe |
Head | Almudron Helm S |
Chest | Basarios Mail S |
Arms | Rhenoplos Braces S |
Waist | Volvidon Coil S |
Legs | Basarios Greaves S |
- Defense: 266
- Fire: 0
- Water: -4
- Thunder: 5
- Ice: -3
- Dragon: -7
- Rapid Morph Lvl 3
- Artillery Lvl 2
- Load Shells Lvl 2
- Guard Lvl 1
- Bludgeoner Lvl 1
Monster Hunter Rise Charge Blade Best Skills
As you create your builds and get further into the game, we recommend working on obtaining these skills.
Skill | What it does |
Guard | Makes it so you don't use as much stamina when guarding. |
Rapid Morph | This skill increases the amount of damage and speed created by form changing abilities. Get it at least to level 3 to make good use of it. |
Load Shells | Gives you more phials to use once you get it to level 2. |
Focus | Makes it so you can charge up your blade a lot faster. |
Charge it up
Once you get the hang of the phial system, the Charge Blade becomes a powerful weapon for both offense and defense. Just make sure to practice between the two modes.
If this doesn't seem like the best fit for your play style, you should consider one of the other weapons available in Monster Hunter Rise.
More navigation links:
All Weapons
