Save $50 on the RoboVac 15C MAX and enjoy spotless floors
You might be working from home, but that doesn't mean you have all the time in the world to clean floors. Pick up the Eufy RoboVac 15C MAX with $50 in savings savings while supplies last!
There are plenty of automatic vacuum cleaners out there, but the RoboVac 15C MAX is one of our favorites for a few reasons. The big thing is its sensor array. The RoboVac 15C MAX has over 10 infrared arrays constantly scanning for ledges and obstacles. This means it can avoid sucking up something it shouldn't, or falling down the stairs, or otherwise getting stuck during operation.
This thing is smart. It's got Wi-Fi built in and support for voice assistants, so with a single booming command, you can get this little underling to start working. It includes a physical remote control, but really, you wanna use the mobile app for all of your settings management and setting cleaning schedules.
Super-smart
With a robust infrared sensor array to detect obstacles, you can rest assured the RoboVac 15C will keep on working for up to 100 minutes without getting stuck or tipped over. Support for voice assistants, its own dedicated mobile app, and a remote control gives you the ultimate convenience.
As low as $209.99
Until April 5, the RoboVac 15C MAX is a whopping $50 off. Just use the coupon code WS15CMAX! It's a great deal, but it won't be around forever! Jump on it now!
