This $6 Veckle Phone Mount uses your car's CD slot
You can get this Veckle CD Slot Magnetic Phone Mount for only $6 today when you click this link and add it to your cart at Amazon. That's $5 off the usual cost, and also the best deal we've ever seen for it. Shipping is free with Amazon Prime, and now is the perfect time to get a free 30-day trial if you aren't already a member since Prime Day is just around the corner.
Veckle CD Slot Magnetic Phone Car Mount
Strangely-shaped vents? No problem. This phone mount uses your car's CD slot. Today's price makes it an easy buy.
Veckle Phone Mounts
$5.99 $11.99 Save $6
There are several styles to choose from, all at one low price. Some items have already sold out, though, so move quickly.
Veckle USB-C Cable 3-Pack
$6.99 $10.99 Save $4
It doesn't have to cost a fortune to stock up on a few new USB-C cables.
Whether your vents disagree with other phone mounts or your dashboard is a bit cluttered, this phone mount might work perfectly for you since it uses your car's CD slot to stay upright. Installation and removal are both super easy processes, and the mount is designed to work with basically every smartphone. This uses a magnet to hold your phone up, and the included piece of metal can either be attached to your phone case using the included adhesive, or it can be slipped between your phone and its case. Either way, the metal piece is thin enough that you shouldn't notice it. Your purchase includes a one-year warranty and it's backed by plenty of positive customer reviews.
