TREBLAB X5 true wireless earbuds are half price through Monday
If you're looking to pick up one of the best true wireless earbuds, you should act now to take advantage of a deal on the TREBLAB X5 true wireless earbuds. Normally priced at $70, they're available for 50% through March 29 using the coupon code MARCH2021X5.
The earbuds are powerful and equipped with noise-cancelling foam eartips. They also are designed to be more secure than some earbuds, making them a great pick if you don't want to worry about them falling out when you're running or any other workout that will get you sweaty. The ear tips come in three sizes so you're sure to find a fit that's right for you. You can also swap out the noise-cancelling memory foam versions for traditional silicone ear tips if you prefer to be more aware of your surroundings.
Enjoy clear sounds for listening to music or making calls with these noise-cancelling Bluetooth 5.0 earbuds.
You'll also have to worry less about them running out of juice. The battery lasts for six hours and the charging case provides four additional charges. When you're listening at a lower decibel level or just using one of the earbuds, you can stretch that time even longer. It just takes two hours to charge them up.
They can also quickly sync with Alexa, Siri, or any iOS or Android device thanks to the Bluetooth 5.0 technology, which also keeps your connection stable up to 33 feet. Not just for playing music, they also feature a built-in CVC 8.0 microphone for excellent call reception.
If anything goes wrong, you can take advantage of the one-year replacement warranty and TREBLAB offers a lifetime of customer support even after that. They're a solid pickup at full price, but definitely worth buying with this deep discount.
Samantha Nelson writes about gaming and electronics for iMore, Windows Central and Android Central while also covering nerd culture for publications including IGN and Polygon. She loves superheroes, RPGs, cooking, and spending time outside with her dog. You can follow her on Twitter @samanthanelson1.
